![]() Join Date: Mar 2011
bed wood choice
I'm getting ready to order bed wood and I have some questions I hope you can answer. What will the best would to use in the hot and dry southern Arizona sun? What vendor have you used for quality products? Thanks. Any help is appreciated.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
It's Better With Nitro
Re: bed wood choice
Is there a particular look or finish that you're going for? How much time will it be out in the elements? What will you be using the truck for?
i wanted to something that took to a red stain well, had some dramatic grain structure that I could highlight, and didn't weigh or cost as much as the harder woods like Oak and Ash. I ended up going with Pine from MAR-K. I used a marine SPAR satin finish. My truck is garaged and only really is out for shows or quick errands around town.
![]() Join Date: Jan 2011
Re: bed wood choice
Did one for a friend of mine that has my old C20 not long ago. We used southern yellow pine and a black stain mixed with linseed oil. We put 6 or seven coats on it. Kind of and old school original look for a truck that gets used as a truck.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Moderator
![]() Join Date: Dec 2012
Re: bed wood choice
Yes, you need to decide if you want a piece of furniture or a working truck bed. Both are nice, but different. I used TREX in my truck that sits outside (and works).
Re: bed wood choice
I have a friend milling some walnut for my truck bed. I will use mine as a truck, so I am concerned about the bed getting scars and such, but it is a truck. I am thinking of putting a rubber mat in the bed when I use it as a truck and rolling it up and storing it in the garage when I don't.
I haven't thought through it all yet though. |
#6 | |
Re: bed wood choice
Re: bed wood choice
Thanks for the input. I want to keep the bed on the lighter side. I have a truck that I use for a truck, so this is going to be a cruiser. It will be a driver but not a worker. I am most concerned about the southern AZ heat. The truck will be inside or in the carport when I'm not driving it, but the sun can be pretty intense sometimes.
![]() ![]() ![]() Join Date: Jan 2018
Re: bed wood choice
I ended up using some white pine from Home Depot (ballin' on a budget) and the wood has done ok sitting outside all the time in GA, but what I didn't use was a sealer, so after about 3 years if being outside, I need to re-stain it, but this time I will be putting some sealer on it.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: bed wood choice
I did the Trex install too and I am very pleased with it.
#10 | |
Re: bed wood choice
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
![]() ![]() Join Date: Feb 2004
Re: bed wood choice
Factory used yellow pine with lamp black and linseed oil. If you want a good solid bed for about 25% of the cost of 3/4 finished yellow pine or 20 percent of a hardwood, use dimensional yellow pine. This lumber has a planed finish and can handle multiple finish.
White pine, poplar, ash, sycamore, redwood are all too soft. If a short step or long bed use all 2x8x8's (yellow pine) which gives you a 3/4" thicker bed when finished. Allow the extra 3/4" when having sawed for width and strips and for bolt lengths. 2x6's are usually white pine. I used a latex water base outside paint - any color- of which I brushed on all none exposed surfaces and on exposed surfaces wiped it off with a wet/damp rag like a stain. I used a gray and my strips will be semi gloss black. You can then leave as is and fix anytime if needed. Hot sun will warp about all boards so you need to get them fastened in the bed soon after sawing.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 06-19-2020 at 07:29 AM. Reason: words |
