06-16-2020, 09:49 PM | #1 |
Carpe manana
Need help sleuthing correct part number: TCS temp sending unit
I've hit a wall in trying to locate the correct part number or equivalent for the temperature sending unit for the transmission controlled spark system for 1972. It mounts in the RH cylinder head and looks like a temp sending unit but has a SINGLE spade-type harness connection. OEM correct example is shown below.
The parts catalog lists group 2.408 #6489600 trans spark control (temp override) but that part number returns units that have a double spade harness connection (example pic below found here: https://www.ss396.com/chevelle/GAC-6...hevelle&year=0 ) Can anyone help with a part number that's correct for this TCS sending unit?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 06-16-2020 at 10:06 PM. Reason: Another pic |
06-16-2020, 10:02 PM | #2 |
Re: Need help sleuthing correct part number: TCS temp sending unit
I removed one from a set of 1972 blazer heads. It is stamped AC 82B. It is a single spade connection
06-16-2020, 10:06 PM | #3 |
Who Changed This?
What I remember from those days is a thermostatic vacuum switch that was installed in the thermostat housing, not something installed in the head. I'm not contesting your reality, just posting what I recall, 48 years removed. Can you post a link to a schematic for the TCS system for '72? I'd personally toss/bypass the parts, but if you're looking for total originality, that wouldn't be the answer you are looking for. It was used for reduction of oxides of nitrogen, btw. It doesn't help with mileage, except for the part where the engine would warm up faster due to the reduced timing advance until warmed up/and in high gear.
06-16-2020, 10:07 PM | #4 | |
Carpe manana
Funny searches using those AC numbers also yield a double spade sending unit like this one here: https://www.carid.com/oe-replacement...r-82b-232.html
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 06-16-2020 at 10:31 PM. |
06-16-2020, 10:12 PM | #5 | |
Carpe manana
EDIT: added schematic
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 06-16-2020 at 10:17 PM. |
06-17-2020, 10:42 AM | #6 |
Is this what you're looking for? https://www.classicparts.com/1971-75...ctinfo/53-608/
72 C10 lwb fleetside -stock 350/350 combo |
06-17-2020, 11:30 AM | #7 | |
Carpe manana
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-17-2020, 11:51 AM | #8 | |
Who Changed This?
