Big Ten?
What years was this name used? What differentiated it from a typical 1/2 ton truck? Was it used on c10 and k10 trucks, or c10's only? Did GMC use this name?
Just a curiosity -- how tacky would it be to put a "big 20" sticker on a "c6p"-equipped 3/4-ton truck? It's sorta' the same thing.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
Re: Big Ten?
Well a C20 is twice as good as a C10. 10x2=20.
So I would do it, and if you get some 70's goodness stickers it will look right. |
![]() Join Date: Feb 2000
Re: Big Ten?
Big 10's were C-10, no K's, C-15 GMC's were called Heavy Half. It was a heavier suspension package and gave you a higher GVWR rating. It was available from '76 through '80.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Re: Big Ten?
Were bigger rear brakes part of the Big 10/Heavy Half option? I have run into different rear brakes on C10s from backing plate-out. The bigger brake backing plates set inward toward the leaf spring more. Not sure on diameter, but wider for sure
Re: Big Ten?
It appears they did get bigger brakes on the BIG 10's per this screenshot of the 1978 Vehicle Info Packet on the GM Heritage site
| Bookmarks |
