Carpe manana
![]() ![]() Join Date: Dec 2010
Tow Hooks: Post your foundry casting marks
I'd like to see detailed examples of the foundry casting marks present on tow hooks for 67-72 trucks. Curious what's out there. These marks can serve as supportive evidence of an OEM part in the absence of part numbers, such as the case with some (most?) 72-only tow hooks. Perhaps for this style one foundry included part numbers but another did not.
Here's a borrowed example that shows what I'm after adjacent to the part number but it lacks detail enough to really identify the mark.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 06-18-2020 at 01:49 PM. |
![]() Join Date: Feb 2000
Re: Tow Hooks: Post your foundry casting marks
Those marks are present on my hooks, not the best lighting with glossy paint but hopefully you can make them out. One hook is more pitted than the other but you can still make out the faint outline of the mark by the part number. Got these out of the junkyard- off an early 50's GMC COE grain truck, the yard owner just looked at me funny and said if you can get them off go for it.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Here’s the best pic I could get of mine. Almost looks like a U with a hexagon around it
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
Roadtrip!
![]() Join Date: Feb 2003
First is an extreme without a part number, second is a 69-71, third and fourth is a 67-68, and last is a pre 67.
Some extremes have part numbers, some don't. Certain extremes seem to have fine thread bolts also if I recall correctly.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Sep 2017
Great thread Pete, however these hooks are forgings not castings. I could be wrong but I would think in a shock load scenario GM would use a forged unit over a cast unit.. Castings have incredible compression strength but don't do well under tension/bending/leverage. Just thought I would point that out, not trying to nit pick or bash
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
Carpe manana
Great point. I’m sure you are correct. I’d like to learn more about the manufacturing process. Am envisioning some molten steel poured into a mold.
Here’s a set of 72-only I have on the shelf. Look like a circle (or a worn hexagon) with a “U” and no part numbers. Thanks for posting. Let’s see some more. Edit: quick video here reviews basic differences between forging vs cast techniques. I have a lot more appreciation for these forged pieces: https://www.youtube.com/watch?v=H9qTcAyMuPU
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 06-18-2020 at 10:17 PM. Reason: Added |
![]() Join Date: Aug 2013
72 extreme bends
With Foundry And Part # Last edited by Chevyland; 06-18-2020 at 11:11 PM. |
Another set of extreme’s
With foundry markings But No part number |
Carpe manana
Interesting that so far these all have a “U” logo/mark. That denotes a particular foundry - I wonder which?
Also, it seems as though the non-part numbered 72s have a mark featuring more of a circle rather than a hexagon.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: Feb 2004
Same casting mark as Deadhead and others.
p/n 3663349-50 http://67-72chevytrucks.com/vboard/s...d.php?t=708395 Frontwards , backwards, right, wrong -- supposedly these correct 60-68 tow hooks in my opinion are overkill for a 1/2 ton or 3/4. I bought the pair and they had what I think are the original 5/8" grade 8 fine thread bolts and I mounted them with 4 new grade 8 coarse threads with the thick washers and lock washers on the inside. I used 69 front leaf spring hangers --I do not know if they differ in design of a 67 K10 but there was little room for mounting them on the frame. As I said earlier they both curl the same direction which is not noticeable but either correct or incorrect. If anyone has a pair of p/n 363349-50 that curls opposite mine I will trade you one. There is no gm info I can find and it appears that 67-72 has more info -right or wrong- on them than anywhere on the web. My assembly book does not show them at all.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 06-19-2020 at 09:13 AM. Reason: words |
![]() Join Date: Sep 2013
Extremes. Both curved in the same direction so same part #.
1969-72 non-extremes. Not curved in same direction so different part # on each.
#13 |
All about them K’s
![]() Join Date: Jun 2014
Cool thread Pete... I need to round a set up for my truck.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#14 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Here's mine, no part #'s on these extremes. Great thread Pete. Cool video too. I never thought I would learn something from a golf video....lol
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man Last edited by Ol Blue K20; 06-19-2020 at 11:34 AM. Reason: add to message |
#15 |
[QUOTE=DeadheadNM;8759996]Great point. I’m sure you are correct. I’d like to learn more about the manufacturing process. Am envisioning some molten steel poured into a mold.
Pete, have a gander at this wonderful video from the 50's. You will have a good understanding of the process and benefits of forged products. Plus there is some amazing equipment and machinery that is just plain awesome https://m.youtube.com/watch?feature=...&v=v2_0V58ocq4 I fixed the link, it should work now
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set Last edited by Bones72Super; 06-19-2020 at 08:37 PM. |
#16 | |
Alloy Artifacts - Trademarks and Logos from browsing that site, they don't seem much interested in taking on our query but maybe a smooth talking rep could get one their researchers on the case.. had these pictures handy of a couple pair of regulars.. I'll try to get better pictures of these and the extremes I have.. ![]() ![]() ![]()
I started out with nothing - and I still have most of it |
#17 | |
http://www.shultzsteel.com some pictures here http://testshultzsteel.com/Equipment/Capabilities.aspx check out what they have now ![]() Huge hydraulic press goes to work in California
#18 |
I'm trying....
![]() Join Date: Oct 2013
'71 Flint Blazer. Not great pics, tried to sharpen them a bit.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#19 |
Carpe manana
Bones - I’m awestruck at the content in those films. Thanks for posting. Amazing. I’ve got a lot of admiration for those steel workers and grateful to have real forged examples.
Here’s a rear tow hook shot from the first film. Thanks for posting guys. Killer I’ll check that out here shortly. Too cool. BTW the US Patent office likely has this forge mark/logo in their searchable data base. Looks like the searches are somewhat convoluted but I’ll give it a go when possible.
#20 |
![]() ![]() Join Date: Sep 2008
These have the marking, but no part number. Notice the white paint.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#21 |
The octagon with the letter inside was American Steel Foundries with the letter being the location of the city or branch.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
#22 | |
Carpe manana
#23 |
Did American Foundries have a location the started with a "U"?
The Hex symbol sure points to them, but that Registry doesn't show a "U" location.
#24 |
73-80 tow hook casting -- Same U
328072
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
#25 |
borrowing pictures of these I just bought from Ironhorse, hope he doesn't mind
![]() they match the profiles of the fronts perfectly so maybe some genetic relationship although they have different forge marks.. took these close up pictures of part numbers and logo but C or Horseshoe X doesn't seem to match the marks we've discovered so far.. maybe Keith knows someone from the plant who would have some leads? right ![]() ![]() left ![]()
