What torque converter
I need some help selecting a torque converter. I am currently running an turbocharged Inline 6 with a Fitech EFI setup. I am changing from a Th350 to a 700R4. Not a racecar, just a hotrod cruiser that will do the occasional burnout.
![]() I was thinking of something in the 2200-2500 range for a stall, but I also want it to lock up at highway speed (3.73 rear and a 28" tire...cruising rpm will likely be right around that 2500 area). Is 2500 stall too high? |
![]() ![]() Join Date: Oct 2014
Re: What torque converter
If you have your cam specs, then I would get those and check with a few different convertor companies to see what they recommend. I have a 700r4 and am using an FTI convertor. It has lockup and seems to work well.
#3 | |
Under normal circumstances, simply adding forced induction doesn't require a Torque converter change.. As was stated previously, check with the camshaft manufacturer for torque converter recommendations.. |
Post Whore
![]() Join Date: Feb 2016
Congratulations on your combination. It sounds cool!
I recommend giving Continental Torque Convertors a call. They are a smaller company that is happy to build one off units for special applications. As opposed to the big companies that select the closest thing they build out of the catalog and send it.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Heres the cam specs (attached). It runs surprisingly hard for a chinese turbo thats probably too big, hence the bit of lag. But its a fun truck to drive. That said, I'm not looking for ET or a perfectly match combo. Really looking for something thats going to have a slightly higher than stock stall speed and have good driving characteristics.
![]() Join Date: Dec 2009
In the past I run Art Carr transmission parts.
He owns a business in Huntington Beach, CA now. As he states on his web page Don't be Fooled! WE ARE NOT CONNECTED or AFFILIATED with ART CARR PERFORMANCE of TEXAS, or ACT TRANSMISSION of NORTHRIDGE, CA These parts were very good quality. And never had any trouble with the trans after the rebuild. Here's link. there is also info about TV cable for the 700. Link:http://cpttransmission.com/techinfo.htm .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I've used Yank and Circle billet converters in the 3000-3200 stall range on a few projects and they drove like stock until you leaned on it. Buy a good converter. FTI has good rep on LS1tech. Yank and Circle kind of start in $450 -500 range. Make sure you run a good trans cooler. A stall converter will create a bit more heat. Call them and see what they recommend.
