![]() Join Date: Jan 2007
1-wire alternator question
Am I crazy or is wire #915 not necessary?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Re: 1-wire alternator question
I'm not sure why it's there since it should get power from #916 anyways.
![]() Join Date: Mar 2005
Could it be so the battery meter (pseudo amp meter) works correctly. It shows the difference in the current at the battery and output of the alternator.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
Post Whore
![]() Join Date: Feb 2016
I believe Tdangle is correct. The drawing is incomplete and only shows the main power circuit.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thanks. Glad I asked, apparently I need to do a bit more research.
One thing, I've read, here, and other places. With a one wire alternator, it is a good idea to ground the alternator case directly to the battery. I don't have the knowledge to tell you why, BUT it couldn't hurt!!! The electron flow to and from the battery will not be interrupted. A ground wire directly to the distributor is a good thing, also...
possibly to help with voltage drop in a long distance wire
This is why I ended up running big ground directly from case to battery...was chasing voltage drop.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
the 3 wire type are better with a ground too
Why do you want a 1-wire? They work great in equipment that cranks and runs all day with minimal accessories but not as nice in a vehicle with variable amp draw. I would wire it as a 3-wire. Just a thought.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
All about them K’s
![]() Join Date: Jun 2014
I agree. The 1 wire doesn’t charge as well at lower rpms.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
From what I’ve been reading I think it will work well for my application as long as I add a good ground. I have a 6-ga for the 1-wire to battery cable, and I don’t have many accessory loads. I like that it’s simple and easy.
I still haven’t found if there’s a way to have the amp gauge functionality.
#13 | |
-klb
#14 | |
![]() Join Date: Apr 2016
1. Like weq92f, wire all the amp draws to a single point and then attaching the alt lead to that point. In the stock configuration, that single point would be a tape-wrapped joint near the driver side headlight. Those wires may be 12 gauge or fatter. 2. From the mentioned single point, connect one of the amp gauge wires with inline fuse. 3. From the mentioned single point, run a 5.5 foot 12 gauge wire to the junction by the battery. Connect the battery to that junction, and also connect the other amp gauge wire with inline fuse to that junction. 4. Do not connect any accessories to that junction, or to the battery, or to the starter lug. If you do, the current draw of those accessories will be invisible to the ammeter. You can change lots of wire lengths and sizes in your electric system, but this one wire that runs from the alternator tie-in junction by the driver side headlight to the junction by the battery is 5.5 foot 12 gauge, it's part of the ammeter design. In reading on the forum about major customizations people do to their truck electrics, it seems to me not many people preserve the amp gauge during those customizations, they switch to volt meter instead. The amp gauge would not be compatible at all with the wiring shown in the diagram in the first post above. |
#15 | |
#16 |
Post Whore
Yes.
#17 |
Excellent thanks everyone. I see why the amp gauge won’t work with my configuration.
#18 | |
![]() Quote:
someone has a video of a working AM meter here. How strong is the deflection from the pointer if it works? |
#19 | |
The Older Generation
In all of my meters that work the maximum deflection is about 1 needle width in either direction from center. LockDoc
#20 |
Thx @LockDoc,
but that's not very much ![]() I tested my once with an 18 gauge wire in the circit, because the display turned out a lot and well. |
#21 | |
The 2 fuse holders in the circuit sometimes get corroded and keep the AMP gauge from working correctly. LockDoc
#22 |
At the body shop.
Mine is 14.4 at 1000 rpms with a giant alternator pulley. Weird
" That didnt make it any newer " " Dont antique the equipment " |
#23 |
Post Whore
The problem is at an idle. The voltage regulators used inside a one wire alternator won't allow charging (or only a very restricted output. There are different versions and manufacturers of regulators used over the years.) if the RPM is too low. At the time it saved GM money. And when the alternator wasn't running it was disconnected from the battery so there was no drain on the battery. The alternator is off below around 350 to 450 rpm at the alternator.
What this means at an idle it is basically a trickle charger. So at night, in the rain, during winter, in stop and go traffic your battery slowly goes dead. This didn't bother GM until they started to put serious computing power in the ECMs. Suddenly having a voltage drop became a much more serious issue. That's why all the newer alternators perform so much better.
#24 |
I could not find the exact same image from post #1 on this thread on the Painless web site.
Another image with the same wiring with #915 & #916 shows them entering the fuse box separately. I could not find an actual schematic of the fuse box to see why they sometimes used separate inputs in this fashion. Separate inputs could be used for Switched and UnSwitched circuits, but not as part of the charging circuits. The image above failed to indicate the 8 gauge wire as their #960 wire. Painless offers charts that help identify wires by assigned numbers. They identify #915 as Engine Section - Alternator B+. They identify #916 as Engine Section, Single Wire - Bat Positive or Start Solenoid. I think what painless does, is provide wire for various configurations and if you don't use all of them, you just tie them together. Oh well, what do their customers know?
'67 GMC 2500, 292, 4spd, AC |
#25 |
It took me forever to find this on their site as they seem to want to push people into using a one-wire Alternator.
This is for a three-wire Alt connection. They use a #995 wire to connect the Alt terminal #2 to their #916 wire and #914 wire for the exciter connection. It still doesn't explain why they are using the #915 as the alternator output as opposed to their #960 in their other drawings. In https://www.painlessperformance.com/Manuals/10104.pdf they tell you how to add a resistor to the #914 and also how to add a Gen idiot light. Now this Painless pdf. is impressive, but you better sit down with a serious adult beverage. In this drawing, they should have the Midifuse as close to the Battery as possible and forget the starter as an alternative. The #995 should be connected directly to the midifuse and not the #916 at the fuse block. #995 is the Sensing wire. It carries very little current, but tells the voltage regulator and alternator, what the battery needs. It does that best by looking directly at the battery.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 06-29-2020 at 01:45 PM. |
