Old 06-22-2020, 12:17 AM   #1
92 Dime
Turn signal/hazzard/headlight issue
Got an electrical problem. '86 GMC 2wd. Found out today I had no rear lights: no turn sgnals, no brakelights. These went out about the time I turned the headlights on in a rain storm.
Checked fuses. None blown.
Checked bulbs. Two were burnt out, so replaced them all. No change.
Removed, cleaned, reinstalled ground connection on the rear frame. That got me a dim glow on the filaments. At one time there was a trailer connector splice in, but this was later cut to disconnect. I removed the electrical tape wrapping it all: water poured out. Got that drying now.
Tried the hazzard lights to see if that had any effect on the turn signals. They were subjectively a little dimmer. I think this was a mistake, as now when I try the turn signals, they function as hazzard lights. Left turn, right turn, doesn't matter: every light that can flash, does.
With the headlights on, I have no lights in the back.
Swapping out the flashers with known-good flashers had no effect on this.
Any recommendations on trouble-shooting from here? Pretty sure (but not certain) that rat's nest where the trailer connector was spliced in is involved. Should I start there?
Where are the grounds from the cab back? (Maybe a better way to put that would be "where should the grounds be from the cab back?")
Worst case scenario, if I splice in new wires from the cab back, any recommendations on wire gauge and number/location of new grounds?
thanks guys. I hate electrical problems.
'89 K1500 350/auto with OD/longbed. DD since 3/24
'92 S10: 2wd, regular cab/shortbed, parked when the gerbils died then given to a friend for an engine swap project
'86 GMC Sierra Classic:2wd/305, shortbed, stock except for aftermarket rust (sold)
92 Dime is offline   Reply With Quote
