Old 06-22-2020, 11:00 AM   #1
72c20customcamper
72c20customcamper's Avatar
77 burban window trim?
Looking to get the plastic chrome insert in the rubber on the front and rear glass . Dont even know where to start looking. It's the only thing that looks bad on my truck.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-23-2020, 02:01 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: 77 burban window trim?
#3 look's like on back order here there other places https://www.lmctruck.com/1973-91-che...hield-and-seal
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-23-2020, 09:52 AM   #3
72c20customcamper
Thanks . It's a start they do have the tears in stock
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
