1969 a/c compressor
i seen this pic of a 1969 c/20 with a/c but i have never seen a compressor this big what the heck is it ?
Re: 1969 a/c compressor
A look at that alt bracket it has a 73 87 set acc brackets
My 69 had the ac on the pass side That would be why the long over the rad hoses 67 72 small blocks had alt on drivers side I would guess and say the compressor is from the square body that donated its engine |
Who Changed This?
![]() Join Date: Jan 2013
Does the AC work? That compressor is designed to run in a Cycling Clutch Orifice Tube (CCOT) system, and you appear to have the POA valve on the AC box. Or has the system been updated to match the compressor?
Old member
The compressor is a late model one. It's not the factory compressor although it is a Chevy one.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
