Old 06-23-2020, 12:00 AM   #1
jarrodblake
jarrodblake's Avatar
Diy LED turn signals 69-70
I ended up making a set of Diy led turn signals for my 1970 C30. I needed a way to make more room behind the turn signal housings to clear my cummins intercooler. The intercooler mounting brackets where hitting the turn signal bulb sockets. At first I tried using a set of sockets from a 1990s mazda that I had laying around. They were a little more low profile but they were still too long.
I ended up ordering a set of cheap led Surface Mount Oval Amber Turn Signal lights for a truck or trailer. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
IMAG3010 by jarrod vanwinkle, on Flickr
IMAG3011 by jarrod vanwinkle, on Flickr
I started bending the black housing away from the clear lense with my hands, the lense if just glued on. Once it started to separate I went in with a flat head and popped the lense off.
IMAG3022 by jarrod vanwinkle, on Flickr
I then trimmed the black bousing to fit in the turn signals.
IMAG3013 by jarrod vanwinkle, on Flickr
I ended up putting the turn signal lense from the c30 in the mill and milled out a little bit of the lense to fit the leds as the two outer leds are just a little two wide to fit in the lense. You could do the same with a dremel or a grinder.
IMAG3012 by jarrod vanwinkle, on Flickr
Its sits flush in the lense now.
IMAG3014 by jarrod vanwinkle, on Flickr
IMAG3015 by jarrod vanwinkle, on Flickr
Testing the lights.
IMAG3016 by jarrod vanwinkle, on Flickr
IMAG3017 by jarrod vanwinkle, on Flickr
high or flash
IMAG3019 by jarrod vanwinkle, on Flickr
low or running lights
IMAG3020 by jarrod vanwinkle, on Flickr
I trimmed the second one a little bit better.
IMAG3023 by jarrod vanwinkle, on Flickr
IMAG3025 by jarrod vanwinkle, on Flickr
I'm just going to connect my stock connecter to the lights. you can see how much room I have now the stock bulb sockets stuck out like a inch and a half.
IMAG3027 by jarrod vanwinkle, on Flickr
If you wanted to make it plug and play you could get a set of 2057 or 1157 Male Head Extension Connector Plug Socket with Wire Harness and make them plug and play.
https://www.amazon.com/Redcolourful-...omotive&sr=1-1
I plan on getting a set of new lenses as mine are the originals and one is cracked. After I do that I plan on apoxing them in to make them a bit more waterproof. At the moment they just have tape on the back. They still use the stock seal but mine lenses had dirt in them when I took them off.
jarrodblake is offline   Reply With Quote
Old 06-23-2020, 03:26 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Diy LED turn signals 69-70
Nice job sir. They look great.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-23-2020, 07:41 AM   #3
yuccales
yuccales's Avatar
Well done!
yuccales is offline   Reply With Quote
Old 06-23-2020, 08:55 AM   #4
Nice the way you laid it all out with pictures. That's great that you could make those fit and still have the lens mount to it's housing as normal. Does the seal still fit?
Old 06-23-2020, 09:26 AM   #5
JustToxic
JustToxic's Avatar
That's a great idea, looks good.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 06-23-2020, 09:32 PM   #6
jarrodblake
Thanks!
Originally Posted by yuccales View Post
Well done!
Thanks!
I figured someone may want to make there own set. The lights I used were $12 on amazon it would be a cheap upgrade for any one. The seal still fits and once I epoxy the new lenses on it will seal like stock.
Thanks!
Old 06-24-2020, 05:30 PM   #7
jamie72
jamie72's Avatar
wonder if if they could be made to work on a 72?
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
