Old 12-12-2003, 05:33 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
rearend ID please!!!!!!
Blazerman usually helps me on this but I'm home so I thought I'd ask the board
These are a Eaton 3/4 rearends 32 teeth, they are not a open rear, what are they for sure, or where can I look for #'s to find out? Thanks for the help Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 12-12-2003, 05:34 PM   #2
teeitup
teeitup's Avatar
hi
1980 chevy swb 4x4
Old 12-12-2003, 05:43 PM   #3
1969 GMC
1969 GMC's Avatar
look like detroit lockers...perhaps
the pic I am attaching is of a detroit locker in a ho52.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-12-2003, 09:48 PM   #4
teeitup
teeitup's Avatar
they look alot alike.
1980 chevy swb 4x4
Old 12-12-2003, 09:57 PM   #5
MJN
MJN's Avatar
Those Eatons did come with detroits in them, if they are factory then they're detroits. Nice find!
Old 12-12-2003, 10:02 PM   #6
teeitup
teeitup's Avatar
How do I determine ratio? Thanks Randy
1980 chevy swb 4x4
Old 12-12-2003, 11:53 PM   #7
Baradium
Binder Rep
Baradium's Avatar
Rotate the gears, there should be a set of numbers stamped in the ring gear, divide the numbers and they will give you the ratio.
You can also count the teeth on both the ring and pinion gears and divide them out. With them out of the truck those two are probobly the only realistic ways to do it easily.
Baradium is offline   Reply With Quote
Old 12-13-2003, 12:38 AM   #8
teeitup
teeitup's Avatar
No numbers stamped on ring gear, and you can't see the pinion. Another locker I had was the same with no numbers on it. Thanks Randy
1980 chevy swb 4x4
Old 12-13-2003, 12:45 AM   #9
breeh
Recovering 67-72 Addict
breeh's Avatar
4:10 is the most common ratio. They could also be 4:56 or 3:54.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 12-13-2003, 12:47 AM   #10
lukecp
Formerly yellow72custom
lukecp's Avatar
See how many turns of the pinon it takes to rotate the ring gear around once. Would proably be easier than counting teeth when the 3rd member is out of the rear like that
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-13-2003, 12:49 AM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Randy, You should be able to see a series of stamped letters and numbers near the top of those slugs. It will be on the R/H side between the cooling fins. If you give me those numbers I will be able to identify them for you. I can tell you the gear ratio and weather or not they are lockers. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-13-2003, 12:52 AM   #12
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Randy, are you sure they only have 32 teeth? I cant think of any ring gear with that few of teeth. Try this, mark a tooth on the ring gear with chalk and index it at the top of the case, mark a spot on the yoke and index it with a mark on the case, make 1 full revoulotion with the ring gear and count the number of times the yoke turns. Like 3-3/4 turns=3.73 4-1/2=4.56 just match it to the closest available gear ratio.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 12-13-2003, 01:10 AM   #13
teeitup
teeitup's Avatar
Thanks guys, I'll try tomorrow when I get back from KC, if it doesn't snow too much. Yes Rob, I counted them twice and two of the one leggers had 32 teeth.
Thanks guys Randy
1980 chevy swb 4x4
Old 12-13-2003, 05:38 PM   #14
1969 GMC
1969 GMC's Avatar
The 3.54 ratio wasn't available in the HO axles. If it is 3/4 ton or 1 ton, then its either 4.10 or 4.56...if that is out of a 1 ton dually, then it is 5.14.
1969 GMC K2500
1996 Honda Accord
Old 12-13-2003, 11:55 PM   #15
69k5
on those eaton third members look at the but end of the pinion and look at the last 2 two digit numbers and divide them. divide those and thats it. they wont be on the ring gear. you are gonna need a flshlight to look up in there and a rag will help for all the crap. if it has 3 (?? places that have like a 1" round rod") its a detroit ( no spin). if it has four then its open. also if you look inside the little observation hole in the 2nd pic. that one is smooth so its a no spin. if you see teeth then they are open. i also sent a pm to make sure yopu got it i know your busy.
69k5
69k5 is offline   Reply With Quote
