Old 12-12-2003, 05:53 PM   #1
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Unhappy competition headers + Fuel lines
Anyone else have this problem on the passenger side? I just noticed it. Its the second tube back on the passenger side. The fuel lines and one brake line are angled off the frame to go under the engine mount. If I had a digital camera it would be much easier to show you. I tried to move these lines but they wouldn't budge.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-12-2003, 06:19 PM   #2
Prerunner1982
Prerunner1982's Avatar
yep, i blew one of the fuel lines.. i used fuel hose and re routed it.... no problem now. the other lines i bent away from the header a bit....
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-12-2003, 07:57 PM   #3
1FaastC10
1FaastC10's Avatar
i kinda did the same thing as Jon with mine. i cut a section out, replaced it with rubber line, and ran it as far away from the header as i could.
1FaastC10 is offline   Reply With Quote
Old 12-12-2003, 08:09 PM   #4
MylilBowTie
Right turn Clyde
Where did you relocate it? Would it be fine tucked up next to the inside of the frame as much as possible? Or do I need to find somewhere else to place it? Any idea what size the line is?
Old 12-12-2003, 11:06 PM   #5
1FaastC10
1FaastC10's Avatar
i used 3/8" fuel hose on mine, and tied it as close to the frame as i could. never had a problem in the 3 years it was setup like that.
Old 12-13-2003, 12:19 AM   #6
Prerunner1982
i ran the fuel hose over the top of the frame and down the outside of it and zip tied it in place all the way back to the tank, no problem in a couple years now.
Old 12-13-2003, 08:53 PM   #7
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I took all mine out once I caused the leak by trying to move it out of the way like you did. Make sure you check for leaks after you've moved it a bit. I took all mine out and ran steel line back to it .
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
