Old 06-24-2020, 12:09 AM   #1
Low Elco
New build- brakes won’t release
Hi all-
I finally got my 67 swb back on the road and it’s pretty good except that the brakes will immobile the truck after a few miles and be smoking! I’ve backed off the pushrod so far that the pedal arm doesn’t hit the stop pad. Still does it. Here’s the setup- 71 stop plate and pad, 71 brake pedal return spring, custom link sleeve, captain fab bracket, aftermarket s10 style dual diaphragm booster, cpp vette style squashed master, wilwood adjustable f/r valve, all new nicop lines, 3/4 ton calipers, stock narrow drums in the rear. They work great, except they seem to retain a bit of pressure every time you use them, until they get real hot and you don’t go. It’ll drag it down against the motor. Crack the bleeder and pop the pressure, back in business. Any ideas? Thanks, chip
Low Elco is offline   Reply With Quote
Old 06-24-2020, 09:45 PM   #2
PGSigns
PGSigns's Avatar
Re: New build- brakes won’t release
The first thing I would check is the rod in the back of the master from the booster. You may have a miss match.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-25-2020, 09:10 AM   #3
Custom 68
Custom 68's Avatar
Could you have a bad hose or 2 that is somewhat collapsed and not allowing the fluid to return? I assume you replaced those as well?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-11-2020, 01:57 PM   #4
Low Elco
Jimmy
Winner! booster from one place, master from another. had a too-long spacer in the master. Cut the spacer down and used the master adjustment to fine tune. Stops good now. Thanks!
