12-12-2003, 06:05 PM | #1 |
C/10 CLUB MEMBER
Edelbrock Carb/Intake Questions?
Which Edelbrock carb would be best for a fairly stock 350? And could I use it with the stock intake manifold? My other question is when I get the funds I would like to replace the intake as well. Is there a particular one I can use, but still be able to use my factory A/C mounting brackets? If anyone knows that would be great.
thanks...
-Ron- |
12-12-2003, 06:11 PM | #2 |
I think this question was just recently asked. for a stock standerd perf. 350 a 600 Edelbrock is more than adaquete.
If it has a Qjet on it now Id consider keeping it & haveing it properly prepped & tuned for your application. A Edelbrock carb doesnt bolt to the stock intake, would have to use an adapter, bad news. If the engine is otherwise stock, Id personaly leave the intake alone & have your carb redone & tuned. a 600 Edelbrock wont make anymore power than a properly tuned Qjet in your application. John
75 GMC C-15 short/step factory 454, lowered |
12-12-2003, 06:12 PM | #3 |
Howzit?!?
I'm willing to bet the 600 will work just fine. I've read on the board that a 750 is too much for fairly stock 350. I have a 500cfm Edelbrock on my 307 w/performer intake and so far it's a great combo for the little 307. I think it also depends what else you are planning to do.
I think you should do the carb and a performer intake at the same time. IMO A/C mounting brackets, I don't know. I'd have to see where they bolt up... my performer is in the parking lot so I could go look.
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
12-12-2003, 06:19 PM | #4 |
if you do choose an aftermarket carb & Intake over stock, Id personally use Edelbrock Performer intake & a 570CFM Holley street Avenger on a stock 350. thats just me personally, Ive been much happier with Holley carbs lately than Edelbrocks.. John
12-13-2003, 12:50 AM | #5 |
"Ochre Ogre"
2101 Edelbrock intake and a 1406 Edelbrock carb. 5 years of carefree driving compared to a leaking quadra-toilet that always needed something.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
12-13-2003, 12:52 AM | #6 |
Formerly yellow72custom
Yup, 2101 intake and a 1406 is a very well working and proven combo for a stock or mild 350. Works great in these trucks.
I have been running a 2101 intake for abut 30k miles and a 1406 carb for about 20k miles. Both are great!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
12-13-2003, 01:11 AM | #7 |
im going to be running a performer rpm intake with a 1406 carb just for more upper range power in my truck. mostly stock 350. hei and headers to duals. one day a 383
i hope the performer rpm works good on my truck. im polishing it.
70 longbed 496/th400/Ford 9" |
12-13-2003, 01:47 AM | #8 |
its all about the +6 inches
The 2101 is perfect for a stock to mild 350. The 1406...I can't remember which carb that is...the 600 with an electric choke, or a manual choke...
Go with the electric choke...which ever part number it is. |
12-13-2003, 02:21 AM | #9 |
the 1406 is electric choke the 1405 is manual choke
springfield illinois 2003 custom (harley)built from scratch 68 swb Last edited by doughby82; 12-13-2003 at 04:49 AM. |
12-13-2003, 02:48 AM | #10 |
sweet, the 2101 ans 1406 is a great set up.
As far as an adapter plate...no big deal. Still better and cheaper than a leaky "quadra-toilet". (I like that...quadra-toilet...LOFL!) |
12-13-2003, 03:37 AM | #11 |
C/10 CLUB MEMBER
2101 and 1406 sounds good to me. Any of you running your factory a/c bracket with that intake? I really don't want to waste any money on this "quadra-toilet"(lmfao) a new set up would be just in time for X-mas (hint, hint).
-Ron- Last edited by OldSkool71; 12-13-2003 at 03:39 AM. |
12-13-2003, 04:29 AM | #12 |
I "had" a Weiand intake on mine and had to trim the a/c bracket that bolts to the intake so it would clear the runners. I didn't have to take much material off though. It's nothing a bench grinder can't handle.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
12-13-2003, 11:07 AM | #13 |
Hoarding Rusty Objects
Edelbrock performer or performer RPM intake and 1406 carb. Be prepared to re-jet the carb though, I have the same carb on the stock 350 in my chevelle and it runs like a pig (huge clouds of black smoke and horrible mpg) because I dont know how to tune the carb.
1985 Chevrolet K20 Silverado 1994 GMC Yukon Follow me on Youtube! - http://www.youtube.com/user/FuelInjectionSucks |
12-13-2003, 11:56 AM | #14 |
they are pretty easy to tune. start with idle mixture screws first. rurn each one in all the way till you feel it resisting & stop. now back each screw out 1.5 turns.
Thaty should give a good starting point. Sounds to me like maybe your choke is sticking.
12-14-2003, 12:31 PM | #15 |
The electric choke models are jetted quite a bit lower than the manual chokes. This is one reason i recomend them.
12-14-2003, 07:53 PM | #16 |
C/10 CLUB MEMBER
Could I just change out the carb for now? If so what all am I looking at as far as changes or other items needed to complete the installation? If you know.
thanks
-Ron- |
12-14-2003, 07:54 PM | #17 |
just get an adapter plate and some rubber fuel line. You'll need a pipe cutter too.
12-14-2003, 08:02 PM | #18 |
C/10 CLUB MEMBER
Will my kickdown bracket work with the new carb? And will that old choke spring element need to be removed? I appreciate all the input, just trying to avoid as many complications as possible. Need this to be a some transition process, (if possilbe).
-Ron- |
12-14-2003, 08:16 PM | #19 |
Yes your kickdown bracket will work. Mine did anyway.
Just leave the choke thing on there and don't hook it up to anything
12-15-2003, 01:36 AM | #20 |
You may need to get a kit for your kick down...I kinda fabbed mine outa junk I had laying around. Even if you don't get it hooked up, it isn't a big deal (onless you have an overdrive tranny)
12-15-2003, 01:41 AM | #21 |
the kickdown isnt hooked up in either of my trucks. i hope that will change when i covnert to a turbo 400
12-15-2003, 11:36 AM | #22 |
Howzit?!?
I got a new kick-down for a newer (75ish) 350 and replaced the whole cable. It was only like $12 and the new one works much better with the edelbrock carb. (not to mention the old one wasn't hooked up)
My 0.02
