Old 06-25-2020, 06:29 PM   #1
sanford66
sanford66's Avatar
1980 Sending Unit
Need to replace this sending unit 1980 K10 manual transmission. can I run a single tube sending unit or do I need a 2 or 3 tube? The smaller line runs to the front of the truck and is cut and crimped off. The other larger line runs up to the charcoal canister and is the only line hooked up to the canister. And of course the other line is the fuel supply line to the pump. Since basically 2 of the lines are not really connected to anything I dont see what it would hurt to use a single line sending unit. just would like some input before I order a new one. Thanks
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 06-25-2020, 08:44 PM   #2
Dleslie212
Re: 1980 Sending Unit
The crimped off line would be return from fuel pump. You can use a sending unit without a return line as long as your fuel pump doesn’t have provision for a return line as well
Dleslie212 is offline   Reply With Quote
Old 06-25-2020, 09:53 PM   #3
sweetk30
sweetk30's Avatar
3/8" - suction
5/16" - return
1/4" vent line
if using 1 single line and rest capped off make sure the cap is vented or you will build up a vac in the tank and have fuel feed problems.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
