06-25-2020, 09:43 PM | #1 |
What method do you use ........
On the floor patch inner rocker and cab mounts? I have my A pillar off most of the B pillar and I took out the footwell panel as well. While those parts are still on order I do have cab mount and the rocker panel. I trimmed a lot vof the rocker/floor piece [you know the newer inner rocker piece that has about three or four inches of floor]. I have it where it fit in and ran y die grinder along it to cut the old floor out. That is the way I have done the last few trucks I put rockers in. But this time I need all four cab mounts.Since I have the floor fitting I took it back out and started trimming with the plasma cutter leaving only the flanges spotted to the floor. I figured I would drill out the spots from underside then fit up the mount. I have the cab on the tipper flipper dolly so getting under isnt a problem. Just wondering what you guys are doing there. I sometimes take the long way around. Jim
06-25-2020, 09:57 PM | #2 |
Re: What method do you use ........
It's been ten years since we did an inner rocker, but that sounds pretty much how we did it.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
06-25-2020, 11:46 PM | #3 |
All about them K’s
That’s pretty similar to how I did mine. I just laid the patch over what was left of the original inner, marked it and trimmed it to fit.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
