06-27-2020, 01:02 PM | #1 |
Front Brake Fitting Size
This fitting came off the front brake lines of my 70 (drums all around)
Can someone tell me what size this is or a part# I need both pieces Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
06-27-2020, 05:47 PM | #2 |
Post Whore
Re: Front Brake Fitting Size
Hard to certain from the photo without measurements. But I believe it to be a common tee with 3 inverted female flare connections. The 2 end ones should be 3/16" and the center 1/4". The 3/16" & 1/4" designations come from the tubing size. 1/4" tubing should be 7/16-24 and the 3/16" should be 3/8-24 threads. The other fitting is once again I am guessing is a 1/4" tubing inverted flare fitting.
They should be available at NAPA or other Dorman suppliers. If you are unable to find the tee in the 3/16 x 1/4 x 3/16 configuration you can use one with all 3/16 threads and then an 1/4 to 3/16 adapter. (2nd link) https://shop.advanceautoparts.com/p/...7CL4*-49996422 https://shop.advanceautoparts.com/p/...8281/9075429-P
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
