06-27-2020, 10:50 PM | #1 |
Bet you don't see this often
Not only appears to be original, it has something else.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
06-28-2020, 12:10 AM | #2 |
Re: Bet you don't see this often
Tried removing the straight slotted screw yet?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
06-28-2020, 12:24 AM | #3 |
Moderator
Luckily I’ve never had a problem removing the slotted screw. It’s pretty short and doesn’t have a lot of threads.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-28-2020, 11:54 AM | #4 |
Yep,
If it's tight, use an impact screwdriver. Works great!
06-28-2020, 11:59 AM | #5 |
Mine came out with a few taps and regular screw driver
06-29-2020, 02:58 AM | #6 |
06-29-2020, 07:43 AM | #7 |
I have worked on many of those. that slotted screw is one reason I own an Impact Driver (screwdriver you hit with a hammer and the tip turns when it is hit).
06-29-2020, 10:51 AM | #8 |
I’ve NEVER seen a 67-72 8 lug with a slide on rear drum. My ‘50 3600 w/ HO52 is that style. Is this on your ‘70?
Steve weim55 Colorado |
06-29-2020, 12:20 PM | #9 |
I've seen them on Dana 60's but not Eaton rear axles.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-29-2020, 12:40 PM | #10 |
Yes, Dana 60 on my 70 C20
06-29-2020, 02:00 PM | #11 |
Wow, I think of all the brake jobs I did on these trucks back in the day I never ran across a single one with a slide on eight lug rear brake drum. Must be a Dana 60 Thing. Luck of the draw I never worked on that particular application. Steve weim55 Colorado |
06-29-2020, 03:12 PM | #12 |
I have two Dana 60's, but only the '67 has the slotted screws. The '69 does not, but it is a Roadrunner with a 5-lug, semi-floating, Dana 60. He,he.
'67 GMC 2500, 292, 4spd, AC |
06-29-2020, 04:48 PM | #13 |
and I assume 4 speed. 383 or 440?
