06-28-2020, 09:29 AM | #1 |
Roadtrip!
Clutch question on a 72
Getting ready to start putting the 72 jimmy back together and decide to replace the clutch, pressure plate and throw out bearing at the same time.
My question is, the parts store has an 11" clutch kit on hand for about $140. The clutch I took out is about 11 3/4" (probably considered 12") which would be a special order and about $120 more. Any reason why I can't use the 11"? Appears all the bolt holes are the same. Their computer says it should work. I am not off roading or pulling anything with it. Specs: 1972 jimmy 4x4 350 4 speed.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-28-2020, 09:32 AM | #2 | |
The Older Generation
Re: Clutch question on a 72
As long as the bolt holes are the same in the pressure plate and the splines in the disk are the same it will work. LockDoc
06-28-2020, 10:42 AM | #3 |
All about them K’s
For what it’s worth I got a complete Luk 12” kit for my K20 for about $130 from Napa and I’ve been really happy with it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
06-28-2020, 07:48 PM | #4 |
I am a big believer of putting back in what came out in order to avoid minute differences that may make you have to do it twice...
06-29-2020, 11:57 AM | #5 | ||
Roadtrip!
I agree with you. Hard to justify waiting on a special order and spending an extra $120 if I don't need to. We shall see as the install goes...
