Old 06-28-2020, 08:16 PM   #1
nsb29
nsb29's Avatar
Voltage from pin 57
E38 ECM and TCM from a 2008 avalanche at pin 57 I have 10v w/ key on and it fluctuates between 3.4 and 5.3 when running I thought it should be 5v all the time any help would be great
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 06-28-2020, 09:09 PM   #2
dayj1
Re: Voltage from pin 57
Are you referring to pin 57 on ECM connector 1 or connector 2?
Pin 57 on connector 1 is the VSS signal which is a 12v square wave. If you measure it with a voltage meter, it isn't going to tell you much. But it will vary with speed.
Pin 57 on connector 2 is the Bank 1 upstream O2 sensor. It's an analog signal that will vary with the AFR. It's not going to tell you much to probe that with a voltage meter, either.
dayj1 is offline   Reply With Quote
Old 06-29-2020, 09:08 AM   #3
nsb29
nsb29's Avatar
Pin 57 connector 1 being used for speedometer every thing was working fine and then became erratic and quite
