Old 06-28-2020, 09:55 PM   #1
ChadW
Help with driveline angles...
I have a 66 that i am building that is on air and will lay out on its frame...I just got my 2 piece driveline with a rear slip joint and aluminum carrier bearing from Performance Drivelines in Bakersfield Cali...
I have it all installed now and need some help with the drive line angles. Here is where it is right now.
Trans is 4.2 degrees down
First shaft is 0.17 degrees up
Rear shaft is 2.64 degrees up
Pinion is pointing up 2 degrees ( but i think they call this a down angles when figuring driveline angles...
The perches are not welded to the axle tubes so i can make adjustments there with no issue...I have a spacer under the carrier raising it up as well...
I have never setup a 2 piece driveshaft so am asking for help/opinions on the angles that i posted above..
Tks
ChadW is offline   Reply With Quote
