06-29-2020, 10:16 AM | #1 |
Parking Brake Re-work/Re-route
So I am about ready to start buttoning up my truck to finish everything and I figured out yesterday my parking brake crossmember bolts in exactly where my T56 trans crossmember bolted in. So I need to come up with a work around.
My initial thought was to do the 1966 and up parking brake system without the crossmember. Then I starting thinking (dangerous). Could I invert the original crossmember in the original spot under the transmission? With the crossmember facing the correct position but upside down...would it work? Like this picture, but on the underside of the frame and upside down? (picture pulled from this thread) I don't think the angle of the cables would be compromised as it would only be 1/2" or so different. What pitfalls can you think of doing it this way? Just do the 66 parking brake system without the crossmember? If I do the 66 system, is the cable from the eBrake handle the same length as on a 65? Thanks |
06-29-2020, 11:45 AM | #2 |
Re: Parking Brake Re-work/Re-route
If it clears physically, I see no reason it wouldn't work flipped as long as the pivots work in the same direction.
06-29-2020, 12:00 PM | #3 | |
This is how it is setup. I never removed all the Ebrake cables and had it laying on the ground...here is how it is connected now. Last edited by roll_the_dice; 06-29-2020 at 12:16 PM. |
06-29-2020, 01:25 PM | #4 |
Not the best quality pick, but on my truck, the driver's side cable attaches on the driver's side of the bar. The sideways pic has the driver's side on the bottom
To make the flip work, I think you will also have to flip the entire mechanism on the bracket so the front cable can have the proper pull on the system
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-29-2020, 05:43 PM | #5 |
I had to flip my e-brake to accommodate the TH350. The e-brake cables were low when ran through the crossmember holes, so I welded wire rope thimbles into them as guides to prevent rubbing and undo wear. They've performed without issue for almost 10 years. Throwing it out there in case you come across this, too. Here's my not so great pic.
My truck ain't dead, it just smells funny. |
06-29-2020, 06:35 PM | #6 | |
I am going to mock it up tomorrow and check everything out and then take it out and blast the cross member and paint it...then reinstall it. I know I need to replace the passenger side rear cable..as it is frozen, but can mock it up and see how it looks. |
06-30-2020, 02:59 PM | #7 |
To work with my transmission crossmember, I had to cut out approximately 6"x3/8" section where the crossmember bends down. Since it is upside down on mine now, that portion would not let it sit flush to the frame and trans crossmember. I test fit after cutting and all looks good. I am going to clean the crossmember up some and give it a coat of KBS rust inhibitor paint and install it and see how it works. I think it will be fine. Will post installed pics when I am finished.
06-30-2020, 05:43 PM | #8 | |
07-01-2020, 08:09 PM | #9 |
Got it installed today. Fit like a glove. I have not hooked up the cables yet as I need to replace the passenger rear cable and I misplaced one of the cotter pins...so find it or buy a new one. Hard to take pictures on my back, but I think it looks good. better still, I think it will work as intended.
07-01-2020, 08:57 PM | #10 |
also a possibility if you have a little to much cable, or need an offset, garage door cable rollers bolt on.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
07-02-2020, 09:24 AM | #11 |
Good idea on the rollers! I was also thinking an eye hook if needed.
