Old 06-29-2020, 12:26 PM   #1
HeavyHauler
Did you have to cut the frame to install your Boyds sidefill fuel tank?
I am wondering if those who have purchased a side fill Boyds fuel tank if you had to cut the frame in order to run fuel fill tube from the tank on a 1967-1972 Chevy C10.
HeavyHauler is offline   Reply With Quote
Old 06-29-2020, 01:11 PM   #2
mkmc69
mkmc69's Avatar
Re: Did you have to cut the frame to install your Boyds sidefill fuel tank?
I'm going to say no, but I have not installed mine yet. I didn't see where it would be a problem though, just holding it up in place.
mkmc69 is offline   Reply With Quote
Old 06-30-2020, 12:12 PM   #3
Jcfcamaro
Jcfcamaro's Avatar
Mines installed but not hooked up yet. I have alot of room for the hose.
Jcfcamaro is offline   Reply With Quote
Old 06-30-2020, 12:14 PM   #4
Jcfcamaro
Jcfcamaro's Avatar
The camera does it every time.
Old 06-30-2020, 04:45 PM   #5
Peanut74
I notched my frame top rail just enough to give a 3/8" clearance around the filler neck. I wanted to make sure the filler hose would not run against the frame rail and leak.
Peanut74 is offline   Reply With Quote
Old 07-01-2020, 08:05 PM   #6
68shortfleet
No need to cut my frame when I installed a Boyd's tank.
68shortfleet is offline   Reply With Quote
Old 07-01-2020, 09:54 PM   #7
Astro-Balls
Astro-Balls's Avatar
Where are you placing the filler and Cap?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
