![]() Join Date: Mar 2016
1972 Super, lower side molding options
Was woodgrain exterior moulding standard on 72 Supers, or could they be black as well?
![]() Join Date: Sep 2017
Re: 1972 Super, lower side molding options
Woodgrain was standard equipment for Supers unless it was a stepside, but could be ordered however you filled out the RPO sheet.
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
So a Super with black lower molding would have been a special order/option or non-existent? I assume that wouldn’t be on the glove box door, right?
I think the woodgrain and the black lower mouldings had different RPO codes. Someone who is more knowledgeable than I will chime in with all the specifics.
![]() Join Date: Aug 2013
I’ve never seen a Super with black lower moldings
![]() Join Date: Oct 2009
Woodgrain lower molding was standard on both Cheyennes and Cheyenne Supers, so you will not normally see an RPO for lower belt molding on either. Black was not an optional lower molding on these trim levels.
Custom and Custom Deluxe could be ordered with lower black molding (RPO BX2) and it would appear on the SPID if an original option. RPO B85 was the upper bright molding - and it could be added to Custom through Cheyenne trim levels and the RPO would appear on the SPID. The upper bright molding was standard on Cheyenne Supers so you won't see B85 (or BX2) on their SPIDs. Last edited by jocko; 06-30-2020 at 09:47 PM. |
