Old 07-01-2020, 05:16 PM   #1
Astro-Balls
Astro-Balls's Avatar
Rear wheel hub bearing surfaces
On this new to me '67 the rear bearing surfaces are pretty scarred up, what's the best way to remedy this?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 07-01-2020, 05:40 PM   #2
68Gold/white
Re: Rear wheel hub bearing surfaces
It looks to me like the surfaces where your bearings ride are OK, Those need to be good. Might check that. I'm not familiar with 20 and 30 series stuff.
I'm guessing there was moisture in the oil, AND/Or some of the gears lubes are corrosive. It might of had the incorrect lube in it, for a long time. Folks back in the day used what ever they had. If it said gear oil, it GOT used....
68Gold/white is offline   Reply With Quote
Old 07-01-2020, 05:48 PM   #3
72c20customcamper
72c20customcamper's Avatar
Where the bearings sit is smooth ,both of my c20 trucks look the same . The rough area doesn't need to look pretty as it's not in contact with anything .not rust on it just brown grease
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-01-2020, 06:15 PM   #4
72c20customcamper
Check the fit of the bearing on the surface . The beaing should be tight where the bearing seats. That inner ring doesn't rotate the bearing spin in the cup and race.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-01-2020, 06:46 PM   #5
Astro-Balls
OK, sounds good, thanks.
