Old 07-01-2020, 09:06 PM   #1
thirstybob
Oh Man, Header install fail help!
I tried every Yoo Toob how-to I could find. Broke bolt off in head removing stock exhaust manifolds...broke 2 easy outs off trying to remove it. Welded a nut onto the broken bolt, breaks the weld before it will loosen the broken bolt.
Now the question is, are 3909802 heads any good and is $850 a fair price. He states that they've been "completely gone through, ready to bolt on".
1974 C20 454 TH400
I'm supposed to look at them tomorrow.
Any advise would be greatly appreciated.
thirstybob is offline   Reply With Quote
Old 07-02-2020, 06:35 AM   #2
Dead Parrot
Re: Oh Man, Header install fail help!
If the old heads are in good shape, see if a machine shop can help. As a last resort on the old heads, price having the broken bolt hole drilled out and tapped with a larger hole or otherwise repaired. If the shop can repair them, you could also price a complete rework of your existing heads, since they will already be off the motor.
No clue on 802 heads or value.
Dead Parrot is offline   Reply With Quote
Old 07-02-2020, 08:34 AM   #3
wixthedog
wixthedog's Avatar
It’s a tough call, how far down the rabbit hole do you want to go? Might be a good time for some aluminum heads and a cam change.
At the very least I would take your heads off and replace the stem seals while your repairing if you haven’t had any issues or complaints.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 07-02-2020, 10:44 AM   #4
Wikid61
Wikid61's Avatar
https://www.youtube.com/watch?v=YbeKxFBZrF8
Wikid61 is offline   Reply With Quote
Old 07-02-2020, 06:16 PM   #5
Originally Posted by Wikid61 View Post
That is kool. I have never seen something like that before.
Old 07-02-2020, 09:13 PM   #6
thirstybob
Thanks but I pulled the trigger on the 802 heads. He said they came off a 67 BB Vette, for whatever that's worth, and they looked good so I bought them. I just hope I didn't get a big wet and sandy one stuck where the sun don't shine.
Old 07-02-2020, 09:25 PM   #7
Wikid61
Wikid61's Avatar
Back in the '80's Tulsa, a small shop had this set up. A 396 (SS '65 Impala) crank bolt snapped at the hub. They had it out clean a couple of hours after dropping it off.
Old 07-02-2020, 09:48 PM   #8
thirstybob
I miss the ol' tradesmen of yesteryear.
