![]() Join Date: May 2005
Rear End Noise
Yesterday I swapped out my entire rear from the narrower 67-70 style to the 71-72 style. I bought the replacement one from a guy parting out a project and it had been gone through. 3.73 posi, everything looked good to me, but I'm not expert haha.
Anyways, it's making a whinning noise once I get some speed going. Below 30 mph everything sounds fine, and even on acceleration and when I let off the gas the sound is completely gone or at least nothing that I can hear. It seems to rear up when just feather the gas or when under light load. Any ideas? I'm going to go get it checked out but it's pissing me off. Driveshaft was recently balanced and no such noise existed with the old set up in there.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e 1970 Chevrolet K5 Blazer - Project 1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4 1969 GMC Suburban - 5.3 LS, 4L60e Last edited by hevy_chevy67; 07-02-2020 at 12:01 PM. |
Post Whore
![]() Join Date: Feb 2016
Re: Rear End Noise
What ratio? 12 bolts have a reputation for being whiny in the higher numerical ratios. Basically 4:10 and above.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Re: Rear End Noise
It's a 3.73.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e 1970 Chevrolet K5 Blazer - Project 1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4 1969 GMC Suburban - 5.3 LS, 4L60e |
Re: Rear End Noise
When an axle does generate noise it is typical for it to whine on accel - or - coast - or - decel. But rarely more than one of those conditions. So your experience is typical in that regard.
It also occurs in a very specific range because the driveline forcing function is not that powerful compared to the mass of the vehicle, meaning it needs the multiplying effect of resonance in order to generate enough power to be a disturbance. Not like a tire problem, where usually once it starts it just keeps going as you increase speed. It could be a result of an incorrect setup in terms of pinion depth or backlash. If it has been "broken in" in this configuration then it has likely taken a set and there may not be an option other than changing the ring and pinion to a new setup. Driveshaft balance has nothing to do with it. Imbalance is a first order of rotation disturbance; gear whine is a function of the number of teeth on the pinion gear (41 divided by 11 = 3.73, or 11th order of rotation for you). Every time the pinion tooth hits the ring gear it creates a "kick" causing the drive shaft to resonate torsionally, and that's what you are hearing. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 07-02-2020 at 01:15 PM. |
Post Whore
Re: Rear End Noise
I would suspect the ring and pinion mesh. It may not be fixable without a gear set change. But I am no expert. If Randy500 doesn't respond send him a PM. His knowledge about rear ends far exceeds mine.
Re: Rear End Noise
Did you put in posi additive?
Re: Rear End Noise
Yeah I put in a bottle of the AC delco stuff and 80/90 oil. No chirping or any sounds when I'm turning.
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Rear End Noise
Check the backlash, and check for end play on the pinion shaft. The GM 12T should have .006" to .010" of backlash and zero end play...I'm thinking you have a rear end that was never correctly set up, and/or a pinion shaft that has end play due to overtightening the initial preload on the crush sleeve. All repairable if you pinpoint and address the problem now. Jack the rear axle up until both wheels are clear and set it on stands. Pop the cover and capture the lube in a clean pan for inspection and reuse if clean. Pull both axles just far enough to clear the splines in the carrier and attach a mag base dial indicator to check the backlash on the ring gear. You can get under the truck and push in and pull out on the pinion yoke using the drive shaft. There should be zero end play. If there is end play plan on buying a $4 crush sleeve and a $3 pinion seal and re-set the pinion preload. I took the whine out of one of my 72's by simply tightening up the loose backlash by swapping shims from the left side to the right...Here's a manual, https://www.randysworldwide.com/wp-c...l_Complete.pdf
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Re: Rear End Noise
Thanks for the comments everyone.
