Old 12-12-2003, 10:19 PM   #1
Chevelle454
Chevelle454's Avatar
How can I run cooler?
My '84 Caprice seems to run much better with a lot more power when it has only been running a few minutes verses when it is at full operating temp. It is a stock 305.
How can I get it to run cooler? It has a new radiator and fresh coolant. I don't want any expensive solutions, such as electric fans or larger radiators. If there is an easy way to keep it cooler, I'd like to hear some ideas.
Thanks,
Scott
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 12-12-2003, 10:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
160 degree thermostat. i run one in my truck in the summer months and it does run better, gets better MPG too.
Old 12-12-2003, 10:33 PM   #3
jhow66
jhow66's Avatar
It also runs better when it is cold because the choke is still on which makes it run richer. Jet your carb up about 2 sizes.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-12-2003, 10:35 PM   #4
cdowns
cdowns's Avatar
yep the 160 thermo or no thermo at all will make it run cooler BUT you'll also lose alot of heat that comes out of the heater, considering where you live do you want to ride around in a cold car all winter ??????
Old 12-12-2003, 10:41 PM   #5
pierce
pierce's Avatar
There's also an additive for coolant called Water Wetter that helps keep it a certain % cooler.
Synthetic oil...but that's expensive
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 12-12-2003, 10:45 PM   #6
Chevelle454
I forgot about water wetter. I have a full container that I use in my dirtbike radiator... I think I will try some of that.
And yes, I would like to keep my heat...lol
All are good ideas, anything else I could try?
1972 C10
1972 C20
Old 12-12-2003, 11:21 PM   #7
Glen
84? Is that a tbi or carb'd vehicle?
Glen is offline   Reply With Quote
Old 12-12-2003, 11:22 PM   #8
Chevelle454
4 barrel stock carb.
1972 C10
1972 C20
Old 12-13-2003, 02:02 AM   #9
Longhorn Man
Like I said...in the warmer months I run it...In the winter i go with a stock 195 T-stat. Even though my heater runs warmer with the 160...anyone able to answer that one? 110 air temp with the 195, and 125 air temp with the 160...go figure.
Old 12-13-2003, 02:03 AM   #10
dinnut
dinnut's Avatar
you could jet the carb up and put the thermostat like they said. that will probably help alot!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-13-2003, 11:19 AM   #11
Moloko
Hoarding Rusty Objects
Moloko's Avatar
Run a 160 thermo, DO NOT run no thermo. You will actually run hotter because the coolant will not stay in the radiator long enough to properly cool and it will take forever for the vehicle to warm up.
1985 Chevrolet K20 Silverado
1994 GMC Yukon
Follow me on Youtube! - http://www.youtube.com/user/FuelInjectionSucks
Moloko is offline   Reply With Quote
Old 12-13-2003, 04:17 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I've been toying with the idea of running a remote oil filter set-up with a cooler like a tranny cooler to help keep the engine oil temp and engine temp lower.I think this would take some of the load off of the cooling system.It probably doesn't fit into your low budget thought but it would probably cost less than $100.00 and would have the benefit of running dual oil filters if desired.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
