Old 07-04-2020, 01:17 PM   #1
americanmusc1e
americanmusc1e's Avatar
Walbro 450 with factory EFI hanger PSA
I posted this in the sloppy mechanics private FB group, but I wanted to put this here as a PSA.
My turbo LS C10 has a Walbro 450 in a factory 88 EFI blazer tank. The pump is on the stock hanger and 25a fuse, 12ga wire/relay to the sending unit. I lost all fuel pressure the other day. Turns out the pump is fine, but the factory bulkhead connector nearly caught on fire. I was thinking about redoing the tank setup anyway, but just a PSA that the Walbro pump (or any moderate/big HP pump) may draw more amperage than ANY factory wiring can handle.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 07-04-2020, 10:21 PM   #2
Captainfab
60-66 Nut
Re: Walbro 450 with factory EFI hanger PSA
That could have been bad.......
Old 07-04-2020, 10:31 PM   #3
americanmusc1e
Yeah I'm not a fan of sketchy wiring heating up inside my fuel tank. That's why I posted. To hopefully save someone else from burning their truck down.
-- Josh
Old 07-05-2020, 12:51 AM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
It's as simple as not knowing. Not knowing what the capacity of that terminal can handle which is 14a and the current draw of a 450 which can be found easily.
Which is why I made these hats, fits stock tanks, proper terminal rated for 30a
A closer shot of the roll over valve.. cheap mild steel ball got replaced
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-06-2020, 05:14 PM   #5
americanmusc1e
Those look nice! I would be contacting you for one except the 88 tank sticks past the end of my framerails now that my truck is SWB. I figured this was a good time to upgrade the tank, and went with an aluminum replacement tank.
-- Josh
Old 07-07-2020, 02:20 AM   #6
Richard
High amperage draw with the aftermarket pumps is only one reason I chose to use a factory PWM pump for my LS swap.
Richard
Old 07-07-2020, 10:02 PM   #7
americanmusc1e
That's just fine until you have 80lb injectors to feed
-- Josh
Old 07-10-2020, 03:35 AM   #8
Richard
I do not have a race car. The guy at Vaporworx has said that the CTS-V pumps will handle 80 lb injectors with his controller and dual pumps will do over 1000 hp.
Richard
Old 07-10-2020, 01:34 PM   #9
americanmusc1e
Interesting. I didn't realize you were LSA at first. I wonder what the amp draw is on that pump? PWM probably does help.
A quick google search says the factory CTS-V uses dual bosch pumps with around a 20A draw at 60PSI. According to 87chevy that is still more than my factory 80's blazer wiring bulkhead will do. Although it's less than the 25+ continuous amps of the Walbro 450.
What kind of tank are you using?
-- Josh
Old 07-11-2020, 02:21 AM   #10
Richard
Using a modified 90 Blazer tank. Carl the owner of Vaporworx is local to me. Has a ton of knowledge regarding fuel systems and obviously knows a lot about his product. Good info on his website and I found several threads he has contributed to in my search of a fuel system for my LSA swap. Benefits of stock type PWM (what I have gathered from him) Pump has built in reservoir so no need for baffled tank, single fuel line to motor. Less amp draw, maybe not at full throttle with dual CTS-V pumps. But for a driver, idle and cruising can be half or less. An aftermarket return type system running at full tilt all the time will heat up the fuel. Pump will last longer due to not running at full tilt 100% of the time. Fuel delivery can be metered by pressure or map. Not intending to promote his stuff. Just pass on info. I paid full price for his product. He is a super nice guy as well.
Richard
