07-04-2020, 04:51 PM | #1 |
Ignition module issue
My girl has been sleeping peacefully in the garage for a few years. Finally got around to messing with her. Now that she's running again, I'm stumped. It is burning up ignition modules almost daily. I have 12 volts to the hei only when key is on. What would cause these to pop? Maybe the truck doesn't like being out in the sun? Any ideas?
07-04-2020, 05:10 PM | #2 |
Re: Ignition module issue
It's possible your coil is bad. It heats up and shorts out making you think it's the module. Have you tried putting one of the burnt modules back in to see if it fires up? Once the coil cools down it works again for a little while and while you are putting a new module in it's cooling down only to fire up making you think you solved the issue.
07-04-2020, 05:32 PM | #3 |
I've let it sit for a few days between it running and then won't fire. Should be plenty of time to cool off, right?
07-04-2020, 05:40 PM | #4 |
Check the wiring coming out of the HEI, The wires from the module circuit are know to get pinched by tuning on the manifold.
Also use a DVOM to get the actual voltage at the battery, both running and not. HEI's modules do not like over voltage issues at all. The came out in congunction with the internally regulated alternator. Here are the finer facts about the HEI and how to diagnose issues:http://www.crankshaftcoalition.com/w...EI_distributor |
07-04-2020, 06:03 PM | #5 |
Who Changed This?
Are you certain that you have the internal ground strap installed? The one that goes under the coil. If left out, you will get this symptom.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 07-04-2020 at 06:10 PM. |
07-04-2020, 06:55 PM | #6 |
hi guys, are you putting heat sink compound under the module? when i bought my hei from summit, there was not any under the module. put some on and havent had a problem so far. 3-4 years. also check the ground as stated above, good luck. BROWN 70
07-04-2020, 07:08 PM | #7 |
laying low
I strongly suggest buying AC Delco modules over any others.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-04-2020, 07:51 PM | #8 |
The coil ground is attached. I'm sure of that. I have spare hei's, might try just swapping out the whole thing...
07-04-2020, 08:12 PM | #9 |
07-04-2020, 08:35 PM | #10 |
You can pull your Module and get it tested at any FLAPS. I carry a spare, known-good Module in the glove box of both trucks w/HEI. A new one averages about $15. Easy swap in the field as a troubleshooting step.
Fresh Module, still no-start? OK, Coil? Fuel Pump? Etc. Unlike points, you won't have to reset timing.
07-04-2020, 08:36 PM | #11 |
Post Whore
Lots of information in this recent thread that may help you.
https://67-72chevytrucks.com/vboard/...d.php?t=806473
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
