07-04-2020, 06:53 PM | #1 |
Simplest DBW cruise control wiring
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
07-05-2020, 12:54 AM | #2 |
BMW & ASE Master Certified
Re: Simplest DBW cruise control wiring
If you have a factory or repro cruise control then you can just simply connect those 3 wires to the switch...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
07-05-2020, 05:44 PM | #3 |
Gen III Only
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
07-07-2020, 09:00 PM | #4 |
Just did a 2006 with the same tac module as you show and the diagram pretty much matches the exact same switches you have. Customer didnt care about cruise but schematics seem like nothing special. What is different with your momentary toggle switch vs a stock cruise switch
07-07-2020, 09:55 PM | #5 |
My switches cost under $10 so its cheap, easy and clean. it just does not look factory. i generally put the switches very low on the driver side of the dash to semi-hide them but they are still reachable when driving. They can be put inside the center console too but not a reachable. Depending on what factory switch/column you use, the switching logic can be backwards. i.e. pressing the button opens the circuit rather than closing the circuit to apply 12 volts to the TACC. There is a huge writeup on this forum talking about how to use a relay to change the voltage(logic levels) for a mid-80's square body column.
here is a link to it. http://67-72chevytrucks.com/vboard/s...d.php?t=398006
07-13-2020, 09:58 PM | #6 | |
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
07-13-2020, 10:16 PM | #7 |
Nm I found some on amazon on off on momentary and a on off regulator switxh
07-13-2020, 10:42 PM | #8 |
I got a pack of 10 for about $15 on flea bay. They sell both kinds.
