07-05-2020, 02:50 PM | #1 |
400TH Kickdown Wiring - Fused/Relayed or not?
I have a Turbo 400 in my 72 now and will be adding the kick down switch at the gas pedal. I can't find any Chevy diagrams (if it's in my assembly manual...It's hiding real good).
I think I know that it needs IGN switched power, but does it get fused (if so, what size fuse?)? Should it utilize a relay? I'm sure I have seen the kickdown relays NOS for sale. Not that I have to be 100% concourse correct, but I do want to do it right.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
07-05-2020, 03:04 PM | #2 |
Re: 400TH Kickdown Wiring - Fused/Relayed or not?
Depends on if you have an older 400 or newer. When the 400 in my 69 went south I had a newer one here in the shop I had rebuilt. It required a kickdown as the older one didn't. I went with the Lokar kickdown kit, All you had to do is run a wire to a switched connection at the fuse block and the other went to the sender on the trans.
https://www.speedwaymotors.com/Lokar...20(Feb28_2020)
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
07-05-2020, 03:43 PM | #3 |
Fig.36 & fig. 37 of the 72 service manual. 18 ga pink to the pedal switch, 18 ga org. from the pedal out to the trans conn.
07-05-2020, 04:40 PM | #4 |
Thanks folks... Does the pink wire have a fuse inline? I assume 18 ga wire does not need to be relayed.
07-05-2020, 06:09 PM | #5 |
Post Whore
My 67 doesn't have a fuse or a relay. Neither does my GTO. The coil in the transmission draws very little current.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-05-2020, 08:25 PM | #6 |
The pink wire plugs into the fuse box. No inline fuse, no relay.
