Old 07-06-2020, 12:51 PM   #1
HeavyHauler
What do I need to mount accelerator pedal on my 1968 Chevy C10
What else do I need to mount the accelerator pedal for my 1968 Chevy C10 custom? I have the plastic pedal pad and it has two areas at the bottom of the plastic pedal where it looks like two ball studs go into. If you look at the pic you can see a ball stud in the floor board on the right side where the base of the pedal would be.
HeavyHauler is offline   Reply With Quote
Old 07-06-2020, 12:58 PM   #2
Boog
laying low
Boog's Avatar
Re: What do I need to mount accelerator pedal on my 1968 Chevy C10
You need the two ball studs to go there. They are available from some vendors.
Look at LMC Trucks or Classic Parts of America.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-07-2020, 11:37 AM   #3
HeavyHauler
Is that all that holds the pedal pad on to the accelerator?
Anybody know what the accelerator pedal and brake pedal look like for a 1968 Chevy C10 Shortbed Custom fleetside?
Old 07-07-2020, 03:25 PM   #4
Custom 68
Custom 68's Avatar
that's all that holds the pedal to the floor. The accelerator linkage is mounted to the firewall and functions separate.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-07-2020, 10:18 PM   #5
HeavyHauler
Awesome and thanks!
