Old 07-06-2020, 08:44 PM   #1
Kevin7723
Kevin7723's Avatar
Air cleaner assistance
Hey everyone so I was finally able to find an air cleaner set up and was having some trouble getting things to fit properly. I was able to get a spacer for my 250 off of here and found what I was told was an air cleaner for my set up. The air cleaner seems to be just a tad bit bigger than the top of the spacer so it seems to fall down onto it. Is there anyway to get it to sit snug or would this cleaner not be the correct one? I was able to buy the bracket I'm missing for the carb to air cleaner stud so I've got that here as well. Oh please ignore the old tiny spacer set up from the tiny air cleaner that I was running.
1970 Chevy C10 Fleetside
Kevin7723 is offline   Reply With Quote
Old 07-06-2020, 09:33 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Air cleaner assistance
I will see if I can remember to check the air cleaner on my '67 and see what it measures in the morning.
LockDoc
Leon
Old 07-06-2020, 09:54 PM   #3
LockDoc
LockDoc's Avatar
OK, Still enough light so I went ahead and went out and checked it.
Air cleaner hole measures 2 9/16" and the top of the carb measures 2 5/8"
This is a pretty original truck.
LockDoc
Leon
Old 07-06-2020, 09:57 PM   #4
Kevin7723
Kevin7723's Avatar
Thank you! Ill measure out what I have and worse case Ill just post a WTB as Id rather not keep using the mini cleaner that was on there.
Old 07-06-2020, 10:00 PM   #5
LockDoc
LockDoc's Avatar
My spacer looks just like yours.
LockDoc
Leon
Old 07-06-2020, 10:25 PM   #6
mr48chev
mr48chev's Avatar
Rock Auto is showing 2-5/8 for the air cleaner gasket for either a 230 or 250 Fel-Pro 5198
The same thing for my 68 292.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
