Old 07-07-2020, 10:22 AM   #1
54blackhornet
54blackhornet's Avatar
Can Anyone Recommend A Decent Dash Pad ?
On completely confused, just looking for black one with metal strip inside..thanks
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-07-2020, 10:59 AM   #2
68 Stepper
Re: Can Anyone Recommend A Decent Dash Pad ?
I just installed one I got from brotherstrucks, it fits and looks good.
68 Stepper is offline   Reply With Quote
Old 07-07-2020, 10:59 AM   #3
HO455
Post Whore
HO455's Avatar
This thread may help.
http://67-72chevytrucks.com/vboard/s...d.php?t=739020
RIP Bob Parks.
Old 07-07-2020, 11:16 AM   #4
Astro-Balls
Astro-Balls's Avatar
What color do you want? I have an original Dash that I am going to recover for sale.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 07-07-2020, 11:59 AM   #5
gmc684x4
I got one from Scotts Supper Trucks
I do not remember tag on it i think it was oer fit good metal reinforcment
It looked original
Few dacades latter still looks good
gmc684x4 is offline   Reply With Quote
Old 07-07-2020, 01:14 PM   #6
54blackhornet
Thanks guys ! I have read a lot of disappointing stories about the quality of some of the pads available today. Just looking for a black one. I have had my original one off for a year or so. Getting tired of looking at all the holes across the dashboard...
71 C-20
07 Magnum RT AWD
Old 07-07-2020, 01:22 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
I purchased an OER from Summit Racing.
What I got was a Dashes Direct urethane dash pad in black.
I was disappointed in the fit.
Good enough for the truck it was going in, but I would never Use it in a nice truck.
There’s a big hump in the middle that won’t lay down.
Look for a vinyl covered dash pad. They seem to be in the $120-$140 price range if you want a nice dash pad. Dashes Direct use to make them.
Keith
Convert to disc brakes.
Old 07-07-2020, 02:14 PM   #8
54blackhornet
Thanks Keith, I just can’t believe it’s so difficult to produce a simple thing like this ?
71 C-20
07 Magnum RT AWD
Old 07-07-2020, 02:40 PM   #9
truckster
truckster's Avatar
Please come back and let us know what you went with and how it worked out for you.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-07-2020, 03:18 PM   #10
Davidf
The pad I got from Brothers had metal and fit well
Davidf is offline   Reply With Quote
Old 07-07-2020, 04:58 PM   #11
Stover93
I got mine from Horsepower Products on ebay. It fit nice and has the metal strip inside. Good communication from the vendor as well.
Stover93 is offline   Reply With Quote
Old 07-07-2020, 09:53 PM   #12
External
External's Avatar
I got mine from the truckandcarshop.com
Super nice. Was the first thing I did to the truck. Really makes a difference
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 07-08-2020, 08:14 AM   #13
sick472
sick472's Avatar
...What I got was a Dashes Direct urethane dash pad in black. There’s a big hump in the middle that won’t lay down....
I bought one from GMCPauls that came in a box labeled "Made In Taiwan" with a piece of brown box tape over a "Counterpart" label. I'm not sure why they would try to hide the source, but you could read the label through the box tape. Anyhow, it was a urethane pad with the steel backing strip and it looked great out of the box. Upon first install attempt...I got the same big hump at the top middle and slighter humps at each of the top bolt connections. I used a die grinder with carbide bit to slot the top dash holes towards the rear of the truck about 3/16 to 1/4". This created a slot that allowed the bolts to drop into the dash much easier and eliminated the humps. Either my dash holes where wrong from the factory (not likely) or the bolts in the pad are too far to the rear of the truck. Much more slotting and the original holes may start to show in front of the pad...don't get carried away with this workaround, just do a little at a time until it works out!
Now, every place there is a top bolt, there are very slight indentations due to the bolt sucking the metal strip and urethane down. Nowhere near as bad as the humps, but visible at certain angles. Maybe I tightened them too much, but I certainly did not bear down on them...they are just stamped sheet metal nuts after all. I loosened them up this morning so see if it relaxes as I just installed it last night. Overall, it looks good to me and par for the course with respect to aftermarket parts.
This pad is not for the pickiest of people, but may represent the best of the urethane types.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 07-08-2020, 08:16 AM   #14
A1971Blazer
A1971Blazer's Avatar
Dashes Direct brand from SoKyClassics.....fit perfectly
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-08-2020, 01:48 PM   #15
54blackhornet
I just order a black one from Southern Kentucky Classics on the recommendation of a fellow member, $60.00 + freight. Mike at SKC told me they have had no complaints with them. Been offering them since 2002...will report back after I received it..Jack
71 C-20
07 Magnum RT AWD
Old 07-08-2020, 03:43 PM   #16
54blackhornet
Update ! Shipping to me in Oregon was $42.00. Kind of steep but the pad was only $60.00 so I figured $102.00 total for one that is supposed to be good quality is not unreasonable.
71 C-20
07 Magnum RT AWD
Old 07-08-2020, 03:46 PM   #17
A1971Blazer
right now shipping is insane....the big carriers are swamped with parcels
they can charge what they want
1967 C10 Step side
1968 C10 Step side
Old 07-14-2020, 09:09 PM   #18
54blackhornet
I wanted to update my purchase of the black dash pad from Kentucky Classics. It arrived by UPS in a pretty decent triangle shaped box, no damage at all. Pad it self is polyutherene ? Spelling ? It bolted in perfectly with no issues at all. I had the glovebox liner out so install of the nuts and washers was a sap. I installed all the original Philip’s head screws along the leading edge. Will tackle the the fasteners around the dash bazel when I feel like standing on my head the one around the AM radio is tight but doable..overall I would highly recommend this dash pad to anyone looking for a inexpensive upgrade. Everything about the transaction was painless..
71 C-20
07 Magnum RT AWD
Old 07-15-2020, 10:36 AM   #19
54blackhornet
I was surprised to see this on the box.
71 C-20
07 Magnum RT AWD
Old 07-15-2020, 11:50 AM   #20
A1971Blazer
Jack....
the one I got from SoKy had "Dashes Direct" printed on the box
Anyway...glad you're happy with it....I was with mine
1967 C10 Step side
1968 C10 Step side
Old 07-15-2020, 12:14 PM   #21
dagnabbitt
dagnabbitt's Avatar
Are the polyurethane repops less susceptible to cracking? Has anyone had one long enough to find out?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 07-15-2020, 01:06 PM   #22
54blackhornet
Yes Dashes Direct one box. I have no idea on how it will hold up other then what they told me. Since 02 no complaints from anyone.
71 C-20
07 Magnum RT AWD
Old 07-15-2020, 09:04 PM   #23
hjewell2
hjewell2's Avatar
subd
hjewell2 is offline   Reply With Quote
Old 07-16-2020, 10:35 AM   #24
sick472
sick472's Avatar
The poly dash in my other car been installed for 10 years. I have 13K on it... Mostly driving it to work on sunny days. So it sits out on those days, otherwise garaged. It looks as good as the day I got it and has not stiffened up. But, I suspect a vinyl one would last that long too.
1972 C10
1985 K20
Old 07-16-2020, 11:36 AM   #25
dagnabbitt
dagnabbitt's Avatar
Thanks, I have heard people complain that they have a "rubbery" feel to them, but they look good in pics and if they don't crack that's good enough for me.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
