Towing question
I'm going to use a tow dolly to tow my 1967 c10 with a 4-speed manual tranny 170 miles.
Uhaul said I have to remove the drive shaft. I'm thinking neutral would suffice? If I do remove it, would the fluid come out of the tranny? Please don't guess with any reply - I can't afford to mess up the truck ![]() thanx
1967 C-10 4-speed, 350v8 |
Re: Towing question
My understanding is remove the drive shaft as the transmission is not built to lubricate its self from the driveshaft is the reason to remove it
Re: Towing question
The 4 speed manual trans lubricates by splash from the gears and therefore would be ok.
An automatic trans that lubricates via a front pump when the engine is running would burn itself up when towing. In this case you would remove the shaft or, if you have room, unhook it from the axle but leave it in the trans (as a plug) and strap it off to one side. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Jan 2001
Re: Towing question
2WD manual you're fine. 4WD manual or automatic you should remove the driveshaft.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Re: Towing question
thank you truckster and keith, that is what I thought!
#6 | |
![]() Join Date: Apr 2013
Re: Towing question
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
Re: Towing question
I'm going to say that the person who wrote the instructions for U haul for rear wheel drives either assumed that all rear wheel drive rigs are automatic or just figured that It won't hurt anything if people do remove the driveshaft on a manual rig.
Re: Towing question
The manual trans has the same issue that the automatic does. When in neutral the only thing that would be spinning is the main shaft. A manual is splash lubed when the cluster/counter gear is spinning. In neutral it doesn't spin.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Re: Towing question
All the 4spd I have been around had a rear yoke although there is probably some application for a slip yoke. Just pull the shaft and be on the safe side. Thats alot of RPM on the needle bearings at the input shaft.
#10 | |
Re: Towing question
Ps you also need to leave the key on and disconnect the battery so the front wheels track on turns
#11 | |
Re: Towing question
Re: Towing question
Problem solved, I decided to use a drive on trailer, only a few bucks more
![]() thanx for all the replies.
#13 |
Post Whore
![]() Join Date: Feb 2016
Re: Towing question
Money well spent especially if you are going to have to back up for any distance. Backing a tow dolly, with a tow vehicle that has a wheel base longer than a Blazer, is very difficult at best.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
