07-07-2020, 02:26 PM | #1 |
Gas Pedal ID?
I’m at a slight bump in my build and need some help identifying my gas pedal assembly. I ordered the spring and nut from LMC but it just isn’t matching up like it should. As always, I could be doing something wrong.
Pictures!
Mike 1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop Obligatory Build Thread HERE! 1979 C20 RCLB - 350 - TH350 Auto |
07-07-2020, 03:22 PM | #2 |
Re: Gas Pedal ID?
It looks like a '71-'72 pedal. Can you post a picture of the front of it? '73 and newer were wider at the bottom, not rectangular.
https://www.classicparts.com/1973-Ac...tinfo/39-319/#
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
07-07-2020, 05:18 PM | #3 |
Re: Gas Pedal ID?
I have to agree. But I have seen a slight few of the early 73 with the 71-72 style pedal on them but most would be the later style.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
07-07-2020, 06:24 PM | #4 |
Re: Gas Pedal ID?
Here’s a pic of the pedal as assembled as well as where it’s bolted to the firewall.
Thanks for everyone’s help!
07-07-2020, 06:44 PM | #5 | |
Re: Gas Pedal ID?
https://www.classicparts.com/1967-81...ctinfo/39-331/ https://gmclassics.com/part/accelera...ough-firewall/ My pickup was built in 75 but titled a 76 so this may explain some things.
Mike 1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop Obligatory Build Thread HERE! 1979 C20 RCLB - 350 - TH350 Auto Last edited by wixthedog; 07-07-2020 at 06:50 PM. |
07-07-2020, 10:57 PM | #6 |
Re: Gas Pedal ID?
Wixthegog you have the same gas pedal as the one in my 75-C10. Lmc sent you the wrong spring for your pedal.
My factory gas pedal spring looks just like the spring in this link. Except my original spring is all grungy. LOL https://www.classicparts.com/1967-81...ctinfo/39-331/
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. Last edited by ron350; 07-07-2020 at 11:05 PM. |
07-08-2020, 03:53 PM | #7 |
Re: Gas Pedal ID?
Thanks for the confirmation, you guys rock!
I’ll get the right spring ordered.
07-09-2020, 10:57 AM | #8 |
Re: Gas Pedal ID?
Based on the parts catalog there are a few different pedals through the years but based on the illustration page they show one style for C/K models- same as my '74 has. There is some detail about 1st design vs 2nd design and what to look for.
