Old 07-10-2020, 06:52 AM   #1
easyrider
easyrider's Avatar
vent window repair
I just replaced the rubber on my 68 vent windows. I followed the video from Brothers and it was very helpful. The replacement went well, with a few problems getting the rubber to seat in frame, but the problem that I ran into was; that once the vent glass was installed the rubber kept it from closing. I thought it might settle as it sat closed, but it hasn't. it seems to be because of the rubber at the front and bottom of the glass not having enough room to let the glass slip by. Has anyone else had this problem? if so, what did you do to make it close easier.
easyrider is offline   Reply With Quote
Old 07-10-2020, 03:45 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: vent window repair
Read through this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=660294
Probably the most comprehensive comparison on wing vent window rubber gaskets on the board. Most of the comparison posts are on page 2 and 3.....
LockDoc
Leon
Old 07-10-2020, 07:18 PM   #3
tim_mc
tim_mc's Avatar
My vent window seals were TIGHT when I rebuilt them, however they are getting better after several months, and probably a few hot days in the sun.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
