Fuses?
I just want to confirm the panel lights and cluster feed fuses are 3 amp fuses. For some background, the reason I ask is my panel lights stopped working. I believe its the headlight switch, but while checking the fuses I noticed I had what appears to be a much higher amp fuse in the panel lights fuse location. I looked up some old posts that had pictures of the fuse panel and saw some that also had a larger fuse in the panel lights location. The fuse block says 3A on it. Is having a larger fuse in the panel lights location an indication of a problem? Should I put in a 3 amp fuse? Thanks for any help.
Re: Fuses?
A fuse is used to protect a circuit and should be the weakest "link" in the circuit. The fuse's purpose is to protect the wiring, not the item. Never add an item to a circuit that requires a higher rated fuse than was originally in the circuit, the wiring probably won't support the additional amperage.. Burned wiring and/or a fire could be the results.. In your case, install a 3 amp fuse in the pnl lps position and see if it holds.. If the fuse blows, check the circuit for a short or other source of overload..
Re: Fuses?
Good Advice from Rusty! I'm no electrical whiz-bang, but the wires that make up the cluster lamp circuits are 20 gauge wires and should be able to carry, in the neighborhood, of 8 amps. The general likely sized those fuses to be on the safe side knowing that they were not pushing the circuit with only a few bulbs. That may be why a larger fuse has not caused any problems for you. Do what rusty says...put a 3 amp back in and see what that gets you.
Here is a recent thread of mine that will show all the fuse sizes and locations along with "our" conclusions regarding the SFE vs AGC styles.... https://67-72chevytrucks.com/vboard/...d.php?t=808513
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 Last edited by sick472; 07-10-2020 at 01:35 PM. Reason: added link |
Re: Fuses?
Thanks for the info. I will put a 3 amp fuse in there and see what happens.
Another question for Sick472. The picture of the fuse block in the thread you linked shows what appears to be a larger than 3 amp fuse in the panel lights slot. All the pictures I've seen of the fuse block show that same larger fuse in the panel lights slot just like I had. That's what had me questioning. In the cluster feed slot the fuse has a very thin wire I assume is a 3 amp fuse. Is it common for people to use a larger fuse in the panel light location for some reason. I don't think I have anything extra wired to my panel lights so I should be fine with a 3 amp fuse. Thanks again. |
Re: Fuses?
I would think it’s because they could not find a 3 amp fuse. 10,15.30 being most common glass fuse.
71 C-20 07 Magnum RT AWD |
#6 | |
Re: Fuses?
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
