Old 07-10-2020, 06:30 PM   #1
Jeffh
Rochester 2 Barrel
Tryed to fire up the 60 the other day. Prime the carb with a little gas it would run out the gas but no more. Thought well the float stuck/accelerator pump shot, time to put a kit in it. Bought a kit, took it off, was taking the idle screws out and this is what I came up with. Its corroded/eaten into the idle screw threads as you can see at the point of the screwdriver. More so on the right but a tiny hole you can see at the one on the left. I assume the base is garbage? Along with at least the one idle screw? Would any Rochester base work? I don't seem to have one laying around here so don't want to have one sent in to me then be just a little bit different and not work. Actually the motor/carb is from a 67 1 ton carb number 7027105. Any other things I should be aware of in putting a kit in this? Been awhile since I've worked on one and have had varying success with them in the past.
Jeffh is offline   Reply With Quote
