![]() Join Date: Mar 2017
68 C20 4 wheel disc options
Changing to disc and have looked at the faq sticky for fronts. From that it looks like I can swap the complete cross member from a 73-87 truck or just the knuckles and ball joints.
Wondering if anyone has done rear disc and if they used these? https://lugnut4x4.com/product/68-72-...onversion-kit/ Thanks, Joe |
Re: 68 C20 4 wheel disc options
71/72 3/4 ton have front disk brakes. You are going to need the A frames or whole crossmember as the ball joints are different between the early trucks and 71 and up.
Any are going to set the wheels out a bit from the 68 drum brake tread width. The only rub I see on that rear brake kit is that it doesn't have any provisions for park/emergency brake. Most guys use a Cadillac Eldorado rear caliper set and they are a bit spendy. I bought the caliper brackets off Ebay and rotors but haven't got the calipers yet for my 71 GMC 3/4 ton. Work on that truck is stalled out a bit while I get work done on other projects.
