BlahBlahBlah
Five to six lug?
I have a 71/72 SWB C10 frame. Someone rolled a 6 lug posi in the rear. I have a bunch of the 15x8 6 lug four nub steel wheels (none for sale) and was thinking I could convert my front disk five lug to six lug. Seems bassackwards but has anyone done this? I know companies make 6 lug rotors but am unsure if I could simply swap out rotors.
Re: Five to six lug?
Cpp and Ece have them there an aftermarket thing
I was thinking of doing the same thing using newer chevy wheels Picking up a 71 72 chassis this morning since its disc and five bolt i will keep her that way |
There is a wider and narrower rear diffs for these trucks
Loc doc has a list if diff codes https://www.67-72chevytrucks.com/vbo...d.php?t=578793 |
![]() Join Date: Dec 2009
I have not done the conversion.
Seems like they are available thou. https://www.summitracing.com/parts/c...del/c10-pickup https://www.suspensionsuperstore.com...gaughys-63158/ .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
BlahBlahBlah
Keeping the rear 6 lug and converting the fronts to six lug would allow me to use use wheels I already have, saving me money. And not having to replace the rear with a five lug axle assembly of which I would have to purchase, or get five lug axles to convert the six to five which I would also have to purchase, saves me money. I am aware of axle widths.
I will contact CPP directly and see if they make a rotor for what Im thinking of doing. Thanks for the responses so far!!!
#6 | |
#7 | |
71-72 5-lug means disc brakes already so you just need the 'conversion' 6-lug rotors. These are available from many of the aftermarket companies that sell disc conversion kits for those swapping their drum equipped trucks over to disc.
BlahBlahBlah
I guess my thoughts on this were, are these drum to disk conversion rotors made to fit earlier spindles? Or are they just what I was hoping they were, five lug disk to six lug disk rotors that work fine on stock spindles. The questions asked on the product page weren't definitive to me.
#9 | |
A quick O'reilly's check showed 71-72 c10's use A3 outer/A5 inner bearings & a 74 c10 uses A3 outer/A5 inner (both considered the HD/1.25" rotor app; Lt duty/1" rotor apps use the A6 inner).
