Here is one for ya. Maybe you have a solution
I've got a 65 c10 stepside. I thought the original headlight were too dim in sorts so I put in some halo h4 conversion lights from a newer jeep. They look amazing (when they are lit and the problem arises) They work great for about 10-15 min then just shut off. Halo's still are haloing but the H4 bulbs went/go dark. I shut em off for about 3-5-10 min and they work great again for about the same time. What do you think about that? I was thinking they are needing relays. I have relays on my elect. water pump, elect. fan, elect. fuel pump and I dont have any issues with them and I have the elect. fan wired directly to the ignition so it is on always. I didn't have any of the other electric stuff I.E fan.w/p or f/p when I did the install on the lights and they work just fine hence me leaning towards a relay. What do you think because I am still scratching my head on this one. (along with turn signal and both brake lights at the same time not working in the rear out of nowhere but one thing at a time as they say) When it happened or was happening I didn't have any tools with me so I couldn't troubleshoot then a motorcycle accident happened and the truck sat outside for a couple years with no wind in my sail to work on it then, I went hog wild, I went twin turbo, intercooler, blow thru carb, ect ect ( and that is another f&*k story all together and meant for another post. AHHH.............. the joys of having a cool looking old ride never seem to be.....or get dull for that matter. You know, I was just thinking. If everyone knew what we went/go thru to have one of these sweet old gems.............I think a lot of em would turn the other way and run. lol
Re: Here is one for ya. Maybe you have a solution
Yes. Power them thru relays (just like they're done on the Jeeps).
The circuit breaker in the headlight switch is probably tripping. Relays are the way to go.
#4 | |
![]() Join Date: Oct 2006
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Agreed! What they said^^^^^!!!!
Posted via Mobile Device |
Moderator
![]() ![]() Join Date: Aug 2011
Headlight relay thread - http://67-72chevytrucks.com/vboard/s...d.php?t=397695
![]() ![]() ![]() Join Date: Jan 2018
X4 on the headlight relays. I installed a relay harness with my stock bulbs and even that made a big difference. The electrical current that goes to the headlights flows through the headlight switch when operating with factory wiring. The factory wiring can't support the demands modern headlights ask for
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
