White Grease
I have my option on the best White Grease.
I want to get a large pool of what people think is the best white grease for hood hinges, door hinges, etc... on these older Chevy Trucks to know I did not leave a stone unturned
48 CJ2A 63 1500 GMC (LS1 w/ Muncie 4spd) 68 RS Camaro 71 K20 BBC & granny 4 speed 95 2500 4x4 17 HD2500 4x4 Want => 67 C10 short bed w/ Manual Tranny |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: White Grease
Lubriplate makes a good lithium grease. I like to use either motor oil or Marvels Mystery Oil for oiling hindges. Rusted stuff gets Marvels, Automatic Trans fluid, and Acetone, It works better than anything other than Kroil.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Post Whore
![]() Join Date: Feb 2016
Re: White Grease
I'm with Ironangel. Oil for hinges. It penetrates better and is easier to clean up the excess. The other bad side effect of Lithium grease is that it is hard on plastic and rubber. So watch the overspray.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
The Older Generation
Re: White Grease
I quit using white grease a few years ago. After dismantling a few trucks where it had obviously been used for years (especially window risers and door latches) it was either a gummy mess or hard as a rock. In this day and age there are a lot better lubricants than that. Graphite is another one to avoid, especially in speedometer cables and locks.... If I need something greased i use wheel bearing grease and for stuff like hinges I use Liquid Wrench Lubricating oil or regular motor oil. For the more delicate things like locks and upper steering column I use a penetrating oil with Teflon in it like ZEP 45nc. Just my 2¢ worth. LockDoc
Re: White Grease
^^^^This
72 C10 lwb fleetside -stock 350/350 combo |
#6 | |
Re: White Grease
I like PB Blaster lithium grease for latches because it will penetrate between tight pivoting parts and not run off like oil. I agree, it might harden, but by then, I will have removed the part, clean all the old grease off and reapplied. |
Post Whore
Re: White Grease
The problem with Lithium grease and plastic or rubber components is that in its most basic form Lithium is basically inert when applied to them. The problem starts with the additives that get added to make Lithium grease have more uses. Then it gets worse when it is put into an aerosol form. The solvents that make it sprayable are bad for plastic and rubber.
The spray form of Lithium grease is probably the most popular but also the most likely to damage other components. So the grease gets an OK for plastic and rubber but then all of the additives don't which can make it a crap shoot as not all documentation (i.e. the interweb) will show it as degrading to plastic and rubber.
![]() Join Date: Mar 2014
Re: White Grease
I like Tri-Flow clear synthetic Grease. It does not cake up like white or classic greases and is safe on most rubber & plastic.
https://www.triflowlubricants.com/pr...thetic-grease/ Their liquid Tri Flow Superior Lubricant in the drip bottle is excellent for hinge pins, tools, bikes, guns etc. Super Lube Silicone Lubricating with Syncolon (PTFE) is another good one. It does not cake up and is safe on plastics & rubber. https://www.super-lube.com/silicone-...-syncolon-ptfe
Made in America by Americans |
All about them K’s
![]() Join Date: Jun 2014
Re: White Grease
I use Kroil penetrating oil on my locks and my hinges. Never had any issues.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Jan 2001
Re: White Grease
I just took apart an HVAC actuator on my 2002 Yukon. The gears are plastic and the factory used white lithium grease on them.
I like Lubriplate. But I agree that it's difficult to get it into tight spots.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Post Whore
Re: White Grease
I am pretty sure that GM uses PTFE grease in those stupid actuators.
