07-14-2020, 12:38 AM | #1 |
Junior Member
Switching from step to fleet bed question
Hello,
I'm leisurely searching for a truck to build. What if I find a good candidate but it's a step side ( I'd like a fleetside)? Is it easy to swap? I assume so but thought I'd ask. The problem would be finding a clean donor bed I imagine. Are all 60-66 fleet beds the same, other than reverse lamps? Thanks! J |
07-14-2020, 09:08 AM | #2 |
Re: Switching from step to fleet bed question
The bed crossmembers are slightly different between 60-62 and 63-66. You'll need a complete bed to swap over since the crossmembers are longer for the fleetside beds
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-14-2020, 09:54 AM | #3 |
Moderator
Or you can buy new bed sides.
07-14-2020, 11:33 AM | #4 |
Moderator
Yes, full new sheetmetal is not really expensive (in the big picture of a build). Sides, front, tubs, rear cross sill, gate. Of course, if you can get a used bed that's nice, go for it.
07-14-2020, 09:07 PM | #5 |
Junior Member
Thanks guys!
07-14-2020, 10:06 PM | #6 |
Some folks find the steps more appealing than fleetside, so you might be able to find someone who would swap you. I would have considered it myself back before I redid my bed wood. Also one of my side panels and the tailgate are messed up so you probably wouldn't want, anyway.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD Thanks everyone for the help over the years. |
07-21-2020, 05:08 PM | #7 |
And can't say enough good things about the quality of Mar=K stuff, if you need panels, gate, or bed kits.
mine:
292 + TKO500 |
07-23-2020, 08:33 PM | #8 |
I don’t think mar-k sells the Fleetside bedsides yet but I think they have everything else you will need.
07-23-2020, 08:58 PM | #9 |
Junior Member
Thanks everyone.
