BlahBlahBlah
Visor differences?
Is there a difference in the visors for the pick-ups (not talking Blazers)? Or are 67-72 all the same? I feel like I was told there might be a difference in thickness? Im not sure, enlighten me if you can ... Thanks.
![]() Join Date: Feb 2002
Re: Visor differences?
'67-'68 visors were a little thinner. With a couple of 1/16'' thick styrofoam sheets, on each side of a cardboard composite rectangle [~1/8th''?]. The edges had a sort of cloth tape stitched to the perimeter. The OEM ones on my '68 C/10 came apart and I looked. I was going to stitch them back up, but I got some newer blue vinyl visors from a friend who ditched his '72 project and was cleaning up.
'69-'72 visors have something thicker and spongier inside and have vinyl borders stitched on. I'm also noticing the passenger side visor is too short to meet the clip hook on the upper windshield frame. I thought it used to. Might have gotten bent in use. I have my visors unhooked a lot because in AZ I use those folding solar reflector screens to keep the interior from getting up to Baking Temperatures. And Blazer visors are shorter and have a different A-Pillar mount. I wanted to use the blue visors on my blue Jimmy, but they did not fit.
The rod inside the visors is two piece. The stub that comes out sometimes moves. This is not a difference, just a response to Orange Sunshine's short passenger side visor comment
Thanks, Special-K. I'll put some vise-grips on the end and tug it back out.
![]() Join Date: Mar 2000
Be sure to either just tug ( least effective method ) or rotate clockwise while pulling on it ( most effective method to remove ) but do not rotate counter clockwise at anytime.
You should not rotate counterclockwise or use a twisting back and forth motion while removing as the sun visor has a C shaped tube the rod inserts into that will begin to spread open if rod is rotated counterclockwise which will result in visor being loose on rod as the C shaped tube uses the steels tension on the rod to hold it firmly in place. Recommended installation if installing when completely removed for bracket and sun visor arm retainer tip end is, Lube the sun visor bracket rod or tip with a light coating of lithium grease then using a clockwise rotation while apply pressure on the rod firmly into the open end of the sun visor and continue rotating clockwise with pressure applied until rod is fully installed. Paul Jr @ GMCPauls |
![]() ![]() Join Date: Feb 2009
I do, somehow I doubt today's stuff will hold up like these 50 years later
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#7 | |
So clockwise from the inboard on both the Drivers side and the Passenger side?
#8 | |
Paul Jr |
So visors are dedicated Left and Right?
No sun visors are not left and right. Lets see the best way to explain this might be to make a fist with your left hand insert pencil in center on thumb side of hand and rotate pencil clockwise, now turn your fist over with pencil still in same side of your hand and rotate pencil clockwise. If you look at how your hand is closed on pencil when you rotate it clockwise with fist face up and down the pencil is turning the same direction in your hand because it's always inserted from same side of visor.
Paul Jr |
I'll have to think about that one.
Each end of the sun visor is shaped different so the bracket always goes into the same end and sun visor tip always goes into the opposite end, the orientation of the rod running through the sun visor that you insert the bracket into never changes in relationship to the sun visor having that opening for bracket end on left or right side. So when you insert the rod on drivers side you end of with a front and back, the same sun visor installed on passenger side reverses the front and back so what was the front on driver side is the back on passenger side but the orientation of C grasping fingers haven't changed on the rod because bracket is still going into the same end on visor.
Which I had visual references I could post depicting this as I'm sure you would grasp it immediately Paul Jr @ GMCPauls. |
#13 |
Thanks for the info Special-K. I did not know the sun visor had a two piece rod in them. I thought one of the many PO's of my truck had cut it down for some reason. Guess I will need to measure the diameter of the rod and make the second bit. After that I need to find some distressed saddle sun
