07-17-2020, 12:11 PM | #1 |
Power Steering Adapter Advice
I'm putting a power steering pump from a 98 Silverado in my 72 Blazer as part of the serpentine drive setup. I've searched the board and looked at what vendors have, and it looks like there are two basic types of adapters. There are some that are threaded, and some that just drop into the fittings. Those of you who have done this, what do you recommend? Bonus question - I imagine I would want to use the hoses from the Silverado, right? Or does it matter? I don't have the brackets installed yet, so I can't mock it up right now.
Thanks!
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-17-2020, 01:57 PM | #2 |
Re: Power Steering Adapter Advice
Chevy already has this covered you undo the hose and adapter from your stock pump and re install it on your new serpintine pump and done
Other easy way is to use an 80 and up ps box that is oring setup One plus is this wsy is a quicker ratio box then the 67 72 setup |
07-17-2020, 02:01 PM | #3 |
I used the original hoses. Get an adapter for the pump from Summit Racing. Quite simple. That way you will always remember what hoses you need when replacing. Either way you will need an adapter.
Smitty '71 Short Fleetside Spring Valley, Ca. |
07-17-2020, 02:42 PM | #4 |
Chevy has that adapter covered no extra parts needed
You remove the chevy adapter from one pump to the new pump Look at the big nut the hose screws into that is the adapter |
07-17-2020, 05:26 PM | #5 |
Yep, just use the output from your old pump. No adapters needed.
Or swap to the later box. Either way, no adapter
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
07-18-2020, 11:20 AM | #6 |
where hose screw ingot he pump is a 1 inch nut remove that replace the oring and install in the new pump and use your stock lines its what i did on my ls swap
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
