Old 07-17-2020, 06:29 PM   #1
HeavyHauler
Is there a 3 point seat belt or Shoulder/Lap belt system for 1967-1968 Chevy C10
Is there a BENCH SEAT 3 point seat belt or Shoulder/Lap safety belt system that is being sold for 1967-1972 Chevy C10 that does not require any drilling or welding on the cab or any part of the truck?
I want to put 3 point belts or shoulder/lap belts in my 1968 Chevy C10 with bench seats that does not require any modification to the truck itself and is just a bolt in deal.
Anybody have a brand or install anything like this?
HeavyHauler is offline   Reply With Quote
Old 07-17-2020, 07:21 PM   #2
siggyfreud
siggyfreud's Avatar
Re: Is there a 3 point seat belt or Shoulder/Lap belt system for 1967-1968 Chevy C10
I bought mine from Matt's classic bowties here on the forum. You should have a plug you can pop in the cab for the upper mount for the shoulder belt that is already threaded, since it was an option back then.
My install took about a half hour. No drilling required, but I do recommend running a tap through the holes first.
siggyfreud is offline   Reply With Quote
Old 07-17-2020, 07:39 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Got mine from Tom http://67-72chevytrucks.com/vboard/s...d.php?t=657298 and I couldn't be more pleased with them.
Easy bolt-in.... the hardest part was removing the seat to access the lower bolts. Even that was not hard to do.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 07-18-2020, 04:38 PM   #4
AllGoNoShow
Look at my post about having issue with my 68 and Morris Seat Belts (which are the most expensive option and everyone said one of the best). If you have a foldable rear seat like they have in 67 and 68 (with the bolts on the side with the little half circle things) the reels will not clear or mount correctly.
Looking at the floor bracket of the belts sold by the member posted from above, I doubt that that reel would clear either. But I will say his seat belts look like the male portion of the buckle will slide on the belt (like newer model belts), whereas another thing that bugs me about the Morris belts is the male buckle end fits super tight against the seat belt and does not automatically adjust- you have to grab the buckle and belt with two hands to move it.
AllGoNoShow is offline   Reply With Quote
Old 07-18-2020, 11:46 PM   #5
flashed
I love my Morris Classic belts in both my trucks .
flashed is offline   Reply With Quote
Old 07-20-2020, 11:07 AM   #6
68 P.O.S.
There's a lot of companies selling them. The only challenge is finding some that match oem colors.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 07-20-2020, 12:37 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The green ones I got from Tom (post 3 above) were a perfect color match -- except they weren't faded from decades in the sun.
- Mike -
RIP El Jay
