07-18-2020, 11:16 PM | #1 |
How rusty is too rusty?
I've got a rusty cab and am about to start rust repair. Do you know of any builds (with a build thread ideally) that started with a particularly rusty cab? The more progress pictures the better!
Evan B. |
07-19-2020, 12:14 AM | #2 |
Post Whore
Re: How rusty is too rusty?
http://67-72chevytrucks.com/vboard/s...d.php?t=645440 depends on how much time and money you want to tie up in it... I would really assess how bad it is vs getting a good donor cab..i know yall are limited up north though so thatd be a tuff call
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-19-2020 at 12:20 AM. |
07-19-2020, 02:08 PM | #3 |
if the fire wall seam is puffy / back of cab at the bottom were the line of spot welds goes all the way across / window openings checked with glass and rubber out / or major floor work i say find another cab .
patches and rockers and corners are easy . the rest is major work on a already chunky skeleton of a cab thats got problems from the inside out . this mid 80's cab was clean around the windshield with the glass and rubber inplace still . after it was all pulled and the cab media blasted bare i found this . thats firewall and top right pass side corner of windshield frame and few other spots around . just to give you a idea of how to check for a solid cab . the firewall area was pass side upper cowl by the 81-91 hood hinge mount and then the firewall by the gas pedal area .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-19-2020, 02:15 PM | #4 |
then i patched in some repairs to make her solid again . and only 1/3 section of each cab corner was needed .
07-19-2020, 02:18 PM | #5 |
yes this was minimal work but still shows how it can be hiding in areas and what to expect .
and this is how clean my cab is from the bottom . showing how solid of a cab i started with .
07-19-2020, 03:16 PM | #6 |
Rust is directly proportional to one of two things: your sheetmetal/welding skills or the fatness of your wallet.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
07-21-2020, 02:24 AM | #7 |
At the body shop.
Super rusty.
Looks abandoned in National city Ca never seen one rust thru the A pillars like this.
" That didnt make it any newer " " Dont antique the equipment " |
07-21-2020, 01:52 PM | #8 |
I have a 75 cab I am working on. Inner/outer rockers kick panel etc. Nothing too crazy. There are very few videos I can find on this. Unlike 67-72 that has hundreds of build videos. Milkcrate on youtube is a good one. I am trying to figure out if the inner rocker goes all the way to to the edge of the cab mount. I have seen it go to the end and on some just cover the 1 flange on others
