Old 07-21-2020, 01:05 AM   #1
rmneder
AC control lights?
My air conditioning control panel lights haven't worked since I don't know when. I just got them working. I put on new sockets and bulbs and now they work. There are two lights on the air conditioning control panel. One comes off the main under dash harness and the other from the air conditioning harness. The light from the main harness works in conjunction with the cluster lights, but the one from the air conditioning harness comes on with the ignition. Is that normal or do I have a problem. Seems strange to me. Thanks for any advice.
rmneder is offline   Reply With Quote
Old 07-21-2020, 09:39 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: AC control lights?
Both lights should work off the head light switch. Grey wire coming off the switch. Disconnect the one that comes on with key and tap into the one that works with the head lights.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-21-2020, 01:47 PM   #3
sick472
sick472's Avatar
Originally Posted by rmneder View Post
.... One comes off the main under dash harness and the other from the air conditioning harness. The light from the main harness works in conjunction with the cluster lights, but the one from the air conditioning harness comes on with the ignition. Is that normal or do I have a problem. Seems strange to me. Thanks for any advice.
I just went through all my harnesses and my ac panel lights are wired just like you described. I think it is this way because the non AC trucks only had one bulb in the panel and the second bulb and wiring would come with the ac option.... My theory anyhow.
The power for both bulbs ultimately goes through the light switch so that they both dim accordingly.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 07-21-2020, 02:09 PM   #4
rmneder
The power for both bulbs ultimately goes through the light switch so that they both dim accordingly.[/QUOTE]
I expected it to work like you describe, but mine is not controlled by the headlight switch. It comes on when the key is on and stays on. Any Ideas why? Could my air conditioning harness be plugged into the wrong spot on the fuse box?
Old 07-21-2020, 02:26 PM   #5
sick472
sick472's Avatar
If memory serves me correctly, there will be a grey wire with a single female plug that is part of the AC harness that should plug into the fuse box near the top right that is labeled "cluster feed".
Yours is probably plugged in the "Ign Unfused" spot.
1972 C10
1985 K20
Old 07-21-2020, 08:28 PM   #6
rmneder
That was it. It was plugged into ignition unfused instead of cluster feed. Thanks.
